[mapguide-users] Add new template layout to Mapguide Studio
Rui Daniro
ruidaniro at hotmail.co.uk
Mon Feb 2 10:13:57 EST 2009
Hi Chris,
Thank you for your really helpful answer.
Rui
_____
De: Chris Claydon (via Nabble)
[mailto:ml-user+65645-808512115 at n2.nabble.com]
Enviada: 02 February 2009 15:11
Para: Rui Daniro
Assunto: RE: [mapguide-users] Add new template layout to Mapguide Studio
Indeed there is! Studio obtains the list of available templates by calling
the ENUMERATEAPPLICATIONTEMPLATES HTTP operation. If you're curious to see
the response, you can submit the request from the "Web Applications" section
of the web tier test pages.
The information returned comes from the template info files stored in the
www/fusion/templates/mapguide folder in the web tier installation. In this
folder you'll see XML files called slate.xml, aqua.xml, maroon.xml,
limegold.xml and turquoiseyellow.xml. These correspond to the 5 standard
templates you can see in Studio.
To get another template to show up in Studio, all you need to do is drop
your own XML template info file into this folder.
The content of the Slate template info file is shown below. For your own
template, you should:
1) Pick a unique <Name> value
2) Set the LocationUrl to point to the main HTML page in your template
3) Set the <Description> - This shows up in a tooltip when you hover over
the template in Studio
4) Create a 126x96 preview image for your template, and set its URL in the
PreviewImageUrl field.
5) Define <Panel> entries for each of the IDs that you want to be able to
assign components to in Studio - if you've based your custom template on one
of the existing MG templates, you may not need to change the existing
entries.
You shouldn't need to re-start anything to get the template to show up in
Studio, just right-click in the list of existing templates and choose
"Refresh". If you've got everything set up correctly, your new template
should show up in the list. Let me know if you run into any problems.
Chris.
<TemplateInfo>
<Name>Slate</Name>
<LocationUrl>fusion/templates/mapguide/slate/index.html</LocationUrl>
<Description>Slate template</Description>
<PreviewImageUrl>fusion/templates/mapguide/slate/preview.png</PreviewImageUr
l>
<Panel>
<Name>FileMenu</Name>
<Label>Toolbar (Main Menu)</Label>
<Description>The horizontal menu bar displayed at the top of the
screen</Description>
</Panel>
<Panel>
<Name>Toolbar</Name>
<Label>Toolbar (Primary)</Label>
<Description>The main toolbar, displayed across the top of the
map</Description>
</Panel>
<Panel>
<Name>ToolbarSecondary</Name>
<Label>Toolbar (Secondary)</Label>
<Description>The secondary toolbar, displayed beneath the main
toolbar</Description>
</Panel>
<Panel>
<Name>Statusbar</Name>
<Label>Status Bar</Label>
<Description>The status bar, displayed below the map</Description>
</Panel>
<Panel>
<Name>Map</Name>
<Label>Map</Label>
<Description>The main map display</Description>
</Panel>
<Panel>
<Name>OverviewMap</Name>
<Label>Map (Overview)</Label>
<Description>The dialog containing the overview map</Description>
</Panel>
<Panel>
<Name>TaskPane</Name>
<Label>Task Pane</Label>
<Description>The panel displaying the task pane</Description>
</Panel>
<Panel>
<Name>Legend</Name>
<Label>Legend</Label>
<Description>The panel displaying the legend</Description>
</Panel>
<Panel>
<Name>SelectionPanel</Name>
<Label>Selection Panel</Label>
<Description>The panel displaying current selection</Description>
</Panel>
<Panel>
<Name>Navigator</Name>
<Label>Navigator (Zoom Slider)</Label>
<Description>The navigator and zoom slider</Description>
</Panel>
</TemplateInfo>
-----Original Message-----
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2258365&i=0>
[mailto:mapguide-users-bounces at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2258365&i=1> ] On
Behalf Of Rui Daniro
Sent: Monday, February 02, 2009 5:18 AM
To: mapguide-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2258365&i=2>
Subject: [mapguide-users] Add new template layout to Mapguide Studio
I would like to know if there is a way to add a new template layout to the
existent list on Mapguide Studio?
View this message in context:
http://n2.nabble.com/Add-new-template-layout-to-Mapguide-Studio-tp2257619p22
57619.html
mapguide-users mailing list
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2258365&i=3>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2258365&i=4>
_____
This email is a reply to your post @
58365.html
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Add-new-template-layout-to-Mapguide-Studio-tp2257619p2258381.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090202/4ff7ade9/attachment.html
