[ZS2] [mapguide-users] Error class not found
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Feb 3 03:00:49 EST 2009
It means that you are tryin to use a FeatureSource, and select/show
features from the class/table/file called "mainroad",
but that class/table/file does not exist in the given FeatureSource.
To solve the error, finde the place where "mainroad" is being used to
query the FeatureSource,
and replace it with an existing class/table/file.
You may want to change the FeatureSource being used instead.
Regards, Kenneth Skovhede, GEOGRAF A/S
ajid skrev:
> what that means :
> An exception occurred in FDO component. Class 'mainroad' is not found. An
> Exception occurred in method MgServerSelectFeatures.SelectFeatures at line
> 249 in file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
> Plz xplain to me...how to solve taht error. i just wanna replace from find
> parcel code from sheboygan..
> ::: PublicVisitor :::
> www.myguidepages.com
