[mapguide-users] Change Resource map in layout definition
euskalmap
ziburudebian at free.fr
Tue Feb 3 05:21:50 EST 2009
I try your method with this code :
_________________________________________________
// Create a MgResourceService and call GetResourceContent() on the layout's
resource id
MgResourceIdentifier webLayoutId = new MgResourceIdentifier("Library://Ag
Base/Mpg Urbanisme.WebLayout");
MgByteReader byteReader = resourceSrvc.GetResourceContent(webLayoutId);
XmlDocument doc = new XmlDocument();
String xmlLayoutDef = byteReader.ToString();
doc.LoadXml(xmlLayoutDef);
XmlNode parentNode = doc.GetElementsByTagName("ResourceId").Item(0);
if (parentNode!=null)
XmlNode mapRessource = doc.SelectSingleNode("/WebLayout/Map/ResourceId");
if (mapRessource != null)
// Change the <ResourceID> element of the <Map> to the
resource id of *
// the map you're after.
mapRessource.InnerText = "Session:" + sessionId + "//" + ag_url.Trim() +
".MapDefinition";
String xmlString = doc.DocumentElement.OuterXml;
webLayoutId = new MgResourceIdentifier("Session:" + sessionId +
"//Map_40Seignanx.MapDefinition");
resourceSrvc.SetResource(webLayoutId, new MgByteReader(xmlString,
"text/xml"), null);
__________________________________________________
I have (like other users on nabble forum) this message :
An exception occurred in the XML parser.
Exception occurred in method MgResourceContentManager.ValidateDocument at
line 556 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceContentManager.cpp
Have you an idea ?
Thanks
> resource id, which will return the xml content for that web layout.
> Change the <ResourceID> element of the <Map> to the resource id of the map
> you're after. Then save the changes back to that layout's resource id
> using SetResource()
> The next time you load the ajax viewer with that web layout id, it will
> have the new map.
> - Jackie
> euskalmap wrote:
>> Hi
>> Can i change the resource map in a layout defintion by code ?
>> If yes who can i find an example?
>> thanks
View this message in context: http://n2.nabble.com/Change-Resource-map-in-layout-definition-tp2168693p2262581.html
