[mapguide-users] Setup Mapguide OS using IIS on Vista
Jason Birch Jason.Birch at nanaimo.ca
Tue Feb 3 11:56:09 EST 2009
Yes the 2.0.2 installer does not integrate with IIS7.  You have to do a
manual install and then manually register MapGuide with IIS.
There are instructions for this in the following PDF:
http://trac.osgeo.org/mapguide/attachment/wiki/MGOS2onVistaIIS7/MGOS2_on
_IIS7_howto.pdf?format=raw
And if you can mentally translate "MapGuideEnterprise" to
"MapGuideOpenSource" this blog has a tip or two for running under 64bit
Vista:
http://www.webrade.com/blogs/darrin/2008/05/01/ManuallyConfigureMapguide
2009WebTierOnVistaX64IIS7.aspx
Jason
-----Original Message-----
Subject: [mapguide-users] Setup Mapguide OS using IIS on Vista
My OS is the Windows Vista Business Edition and when I tried to install
Mapguide Webserverextensions choosing the option to use IIS as webserver
I
received an error message saying that the installer could not find the
IIS
webserver. Can anyone clarify me on this? I went to check if I had the
IIS
activated and it was, so I don't know why I could not use it.
