[mapguide-users] Change Resource map in layout definition
euskalmap ziburudebian at free.fr
Wed Feb 4 06:31:03 EST 2009
Hi jackie,
I have display the <Map><ResourceId> tag before and after the modify and all
is correct : the modify is OK.
I thinks, perhaps i call my code not in the good instruction in mapguide
file : my code is called before the catchinstruction in the
/mapviewernet/mapframe.aspx
Thanks
Perhaps, the XmlDocument stripped out some attributes in the root element
when converting back to raw xml string content.
> Check the xml content before and after the modifications and see if there
> were things other than the <ResourceID> element that have been changed.
> - Jackie
> euskalmap wrote:
>> Hi,
>> I try your method with this code :
>> _________________________________________________
>> // Create a MgResourceService and call GetResourceContent() on the
>> layout's resource id
>> MgResourceIdentifier webLayoutId = new MgResourceIdentifier("Library://Ag
>> Base/Mpg Urbanisme.WebLayout");
>> MgByteReader byteReader = resourceSrvc.GetResourceContent(webLayoutId);
>> XmlDocument doc = new XmlDocument();
>> String xmlLayoutDef = byteReader.ToString();
>> doc.LoadXml(xmlLayoutDef);
>> XmlNode parentNode = doc.GetElementsByTagName("ResourceId").Item(0);
>> if (parentNode!=null)
>> 	XmlNode mapRessource =
>> doc.SelectSingleNode("/WebLayout/Map/ResourceId");
>> 	if (mapRessource != null)
>>                 // Change the <ResourceID> element of the <Map> to the
>> resource id of *
>>                 //  the map you're after.
>> 		mapRessource.InnerText = "Session:" + sessionId + "//" + ag_url.Trim()
>> + ".MapDefinition";
>> 		String xmlString = doc.DocumentElement.OuterXml;
>>         	webLayoutId = new MgResourceIdentifier("Session:" + sessionId +
>> "//Map_40Seignanx.MapDefinition");
>> 		resourceSrvc.SetResource(webLayoutId, new MgByteReader(xmlString,
>> "text/xml"), null);
>> __________________________________________________
>> I have (like other users on nabble forum) this message :
>> An exception occurred in the XML parser.
>> Exception occurred in method MgResourceContentManager.ValidateDocument at
>> line 556 in file
>> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceContentManager.cpp
>> Have you an idea ?
>> Thanks
>> Jackie Ng wrote:
>>> Create a MgResourceService and call GetResourceContent() on the layout's
>>> resource id, which will return the xml content for that web layout.
>>> Change the <ResourceID> element of the <Map> to the resource id of the
>>> map you're after. Then save the changes back to that layout's resource
>>> id using SetResource()
>>> The next time you load the ajax viewer with that web layout id, it will
>>> have the new map.
>>> - Jackie
>>> euskalmap wrote:
>>>> Hi
>>>> Can i change the resource map in a layout defintion by code ?
>>>> If yes who can i find an example?
>>>> thanks
View this message in context: http://n2.nabble.com/Change-Resource-map-in-layout-definition-tp2168693p2268264.html
