[mapguide-users] Change Resource map in layout definition
euskalmap ziburudebian at free.fr
Wed Feb 4 06:56:32 EST 2009
COMPLEMENTS :
i have display the xmlLayoutDef before modif and xmlString after modif in my
code;
this is a difference on begin of file : before modif the string begin by
<?xml version="1.0" encoding="utf-8"?> and not the string after modif
Regards
Hi jackie,
I have display the <Map><ResourceId> tag before and after the modify and all
is correct : the modify is OK.
I thinks, perhaps i call my code not in the good instruction in mapguide
file : my code is called before the catchinstruction in the
/mapviewernet/mapframe.aspx
Thanks
View this message in context: http://n2.nabble.com/Change-Resource-map-in-layout-definition-tp2168693p2268363.html
