[mapguide-users] Change Resource map in layout definition
euskalmap
ziburudebian at free.fr
Wed Feb 4 10:01:28 EST 2009
Thanks for you help, finally i have resolve my problem. I have an error on
the xml after modif.
Thanks jackie
Regards
COMPLEMENTS :
i have display the xmlLayoutDef before modif and xmlString after modif in my
code;
this is a difference on begin of file : before modif the string begin by
<?xml version="1.0" encoding="utf-8"?> and not the string after modif
Regards
euskalmap wrote:
> Hi jackie,
> I have display the <Map><ResourceId> tag before and after the modify and
> all is correct : the modify is OK.
> I thinks, perhaps i call my code not in the good instruction in mapguide
> file : my code is called before the catchinstruction in the
> /mapviewernet/mapframe.aspx
> Thanks
View this message in context: http://n2.nabble.com/Change-Resource-map-in-layout-definition-tp2168693p2269210.html
