[mapguide-users] Repository or server error
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Feb 5 02:47:56 EST 2009
What does the error log state:
C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
If you can create a MapGuide Package, you can do this:
1. Create MapGuide Package
2. Move the package outside the install dir.
3. Uninstall MapGuide
4. Delete the installation folder
5. Re-install MapGuide
6. Restore the package
That should clear any corruption in the repository.
I doubt that the repository is the problem though.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rodolfo Moreno skrev:
> Hi all,
> I am having an odd issue.
> the problem consists in that the server doesn't send the maps how if these
> did not exist, however when I access to my repository by Maestro or
> Studio2009 I can see and edit all the resources of my repository.
> the events before that the server or repository started to fail are:
> - I was editing my resources using mapguide maestro and mapguide studio 2009
> at the same time.
> - My SQL 2008 trial version has expired today (some of my datasources are
> stored there). But I have tested another map that doesn't use data from SQL
> and the application doesn't work.
> current efects:
> - the majority of the times the applications(using these resources) don't
> work but sometimes these work. (very odd).
> I have restarted the server twice and the error keep on. I guees that for
> some reason the repository has been corrupted. So I was looking for a tool
> that allows to repair the repository in REPOSITORYADMIN directory without
> successful, becuase the tools within of that directory are for restoring.
> or maybe it to be a server error?
> any help will be appreciated,
> Rodolfo Moreno
> CivilEng
