[mapguide-users] Consuming WFS, error in MGE2009
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Feb 5 05:46:54 EST 2009
Arh yes, I should have read the entire mail :).
I'm guessing that the name is a bit tricky because it contains spaces.
MapGuide/FDO has some internal encoding/decoding of non-alphanumeric
charaters.
If you control the service, can you try to rename the table?
Otherwise, I see two options:
1) File a bug report, and wait for it to be fixed (or fix it yourself).
2) Write a small WFS wrapper that translates the names.
Regards, Kenneth Skovhede, GEOGRAF A/S
Gary Morin skrev:
> The map did have the correct coodinates so I don't think it was
> preview problem, we were getting the error mentioned at the botton of
> the the post.
> Error: Failed to stylize layer: tiger landmarks
>         An exception occurred in FDO component.
>         Schema can not be found in the collection.
>  StackTrace:
>   - MgMappingUtil.StylizeLayers line 786 file
> The interesting thing the same WFS worked fine in Map 2009
> Thanks for you replies
> Gary
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* 05 February 2009 07:16
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Consuming WFS, error in MGE2009
> A problem that I see a lot, is that the WFS provider/server does not
> correctly read the extent of the data.
> This means that the preview shows a map somewhere else, and so, no
> data is displayed.
> The cure is to set up a map with the correct extents, and then add the
> layer here, and then preview the map.
> Also, what are the contents of the error log, when no features are
> displayed:
> C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
> or
> C:\Program Files\Autodesk\MapGuideEnterprise2009\Server\Logs\Error.log
> Berdel, Brian skrev:
> Did you try setting the coordinate system in the coordinate system
> over-ride?
> Not sure if this will work for you...as I have not loaded any WFS and I
> am using open source, but when connecting a SQL Spatial Data Source, I
> got a similar error and it was resolved after I set the coordinate
> system in the coordinate system over-ride of the data source. Might be
> worth a try...
> Brian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
> Sent: Wednesday, February 04, 2009 3:55 PM
> To: mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> Subject: Re: [mapguide-users] Consuming WFS, error in MGE2009
> Unfortunately I never found a solution to this problem. I did succeed to
> consume WFS with served by some other servers but in that case some
> other
> problems were occurring (not possible to select features, unstable,
> Gary Morin wrote:
>> I'm using MGE 2009 and trying to consume a WFS published by Geoserver.
>> I'm using Stuido author, create an data connection to the WFS works
> fine,
>> and I can create a layer, but when I attempt to preview the layer no
> data
>> is shown and an error is logged. The same WFS work fine in AutoCAD Map
>> 2009
>> <2009-01-15T10:15:12>              127.0.0.1           Administrator
>>  StackTrace:
> d:\build\carrera_nightly\build_34.2\ent\os\server\src\services\mapping\M
> ap
>> pingUtil.cpp    Failed to stylize layer: tiger landmarks
>> Looking in the mail list archived I found a similar problem reported
> march
>> 2008
> http://n2.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-some
> on
>> e---tt1815194.html#a1815194
>> Was the problem ever fixed, or is this a new problem?
>> Thanks
>> Gary
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090205/f2305666/attachment.html
