[mapguide-users] Consuming WFS, error in MGE2009
Gary Morin gary.morin at keynetix.com
Thu Feb 5 04:14:30 EST 2009
The map did have the correct coodinates so I don't think it was preview
problem, we were getting the error mentioned at the botton of the the
post.
Error: Failed to stylize layer: tiger landmarks
        An exception occurred in FDO component.
        Schema can not be found in the collection.
 StackTrace:
  - MgMappingUtil.StylizeLayers line 786 file
The interesting thing the same WFS worked fine in Map 2009
Thanks for you replies
Gary
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: 05 February 2009 07:16
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Consuming WFS, error in MGE2009
A problem that I see a lot, is that the WFS provider/server does not
correctly read the extent of the data.
This means that the preview shows a map somewhere else, and so, no data is
displayed.
The cure is to set up a map with the correct extents, and then add the
layer here, and then preview the map.
Also, what are the contents of the error log, when no features are
displayed:
C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
or
C:\Program Files\Autodesk\MapGuideEnterprise2009\Server\Logs\Error.log
Regards, Kenneth Skovhede, GEOGRAF A/S
Berdel, Brian skrev:
Did you try setting the coordinate system in the coordinate system
over-ride?
Not sure if this will work for you...as I have not loaded any WFS and I
am using open source, but when connecting a SQL Spatial Data Source, I
got a similar error and it was resolved after I set the coordinate
system in the coordinate system over-ride of the data source. Might be
worth a try...
Brian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
Sent: Wednesday, February 04, 2009 3:55 PM
To: mapguide-users at lists.osgeo.org
Unfortunately I never found a solution to this problem. I did succeed to
consume WFS with served by some other servers but in that case some
other
problems were occurring (not possible to select features, unstable,
Gary Morin wrote:
I'm using MGE 2009 and trying to consume a WFS published by Geoserver.
I'm using Stuido author, create an data connection to the WFS works
fine,
and I can create a layer, but when I attempt to preview the layer no
data
is shown and an error is logged. The same WFS work fine in AutoCAD Map
2009
<2009-01-15T10:15:12>              127.0.0.1           Administrator
 StackTrace:
d:\build\carrera_nightly\build_34.2\ent\os\server\src\services\mapping\M
ap
pingUtil.cpp    Failed to stylize layer: tiger landmarks
Looking in the mail list archived I found a similar problem reported
march
2008
http://n2.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-some
on
e---tt1815194.html#a1815194
Was the problem ever fixed, or is this a new problem?
Thanks
Gary
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090205/a1067910/attachment.html
