[mapguide-users] Consuming WFS, error in MGE2009
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Feb 5 02:15:45 EST 2009
A problem that I see a lot, is that the WFS provider/server does not
correctly read the extent of the data.
This means that the preview shows a map somewhere else, and so, no data
is displayed.
The cure is to set up a map with the correct extents, and then add the
layer here, and then preview the map.
Also, what are the contents of the error log, when no features are
displayed:
C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
or
C:\Program Files\Autodesk\MapGuideEnterprise2009\Server\Logs\Error.log
Regards, Kenneth Skovhede, GEOGRAF A/S
Berdel, Brian skrev:
> Did you try setting the coordinate system in the coordinate system
> over-ride?
> Not sure if this will work for you...as I have not loaded any WFS and I
> am using open source, but when connecting a SQL Spatial Data Source, I
> got a similar error and it was resolved after I set the coordinate
> system in the coordinate system over-ride of the data source. Might be
> worth a try...
> Brian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
> Sent: Wednesday, February 04, 2009 3:55 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Consuming WFS, error in MGE2009
> Unfortunately I never found a solution to this problem. I did succeed to
> consume WFS with served by some other servers but in that case some
> other
> problems were occurring (not possible to select features, unstable,
> Gary Morin wrote:
>> I'm using MGE 2009 and trying to consume a WFS published by Geoserver.
>> I'm using Stuido author, create an data connection to the WFS works
> fine,
>> and I can create a layer, but when I attempt to preview the layer no
> data
>> is shown and an error is logged. The same WFS work fine in AutoCAD Map
>> 2009
>> <2009-01-15T10:15:12> 127.0.0.1 Administrator
>> Error: Failed to stylize layer: tiger landmarks
>> An exception occurred in FDO component.
>> Schema can not be found in the collection.
>> StackTrace:
>> - MgMappingUtil.StylizeLayers line 786 file
> d:\build\carrera_nightly\build_34.2\ent\os\server\src\services\mapping\M
> ap
>> pingUtil.cpp Failed to stylize layer: tiger landmarks
>> Looking in the mail list archived I found a similar problem reported
> march
>> 2008
> http://n2.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-some
> on
>> e---tt1815194.html#a1815194
>> Was the problem ever fixed, or is this a new problem?
>> Thanks
>> Gary
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090205/01cf6c04/attachment.html
