[mapguide-users] Consuming WFS, error in MGE2009
Berdel, Brian
brian.berdel at mcmtrans.com
Wed Feb 4 18:41:46 EST 2009
Did you try setting the coordinate system in the coordinate system
over-ride?
Not sure if this will work for you...as I have not loaded any WFS and I
am using open source, but when connecting a SQL Spatial Data Source, I
got a similar error and it was resolved after I set the coordinate
system in the coordinate system over-ride of the data source. Might be
worth a try...
Brian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
Sent: Wednesday, February 04, 2009 3:55 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Consuming WFS, error in MGE2009
Unfortunately I never found a solution to this problem. I did succeed to
consume WFS with served by some other servers but in that case some
other
problems were occurring (not possible to select features, unstable,
Gary Morin wrote:
> I'm using MGE 2009 and trying to consume a WFS published by Geoserver.
> I'm using Stuido author, create an data connection to the WFS works
fine,
> and I can create a layer, but when I attempt to preview the layer no
data
> is shown and an error is logged. The same WFS work fine in AutoCAD Map
> 2009
> <2009-01-15T10:15:12> 127.0.0.1 Administrator
> Error: Failed to stylize layer: tiger landmarks
> An exception occurred in FDO component.
> Schema can not be found in the collection.
> StackTrace:
> - MgMappingUtil.StylizeLayers line 786 file
d:\build\carrera_nightly\build_34.2\ent\os\server\src\services\mapping\M
ap
> pingUtil.cpp Failed to stylize layer: tiger landmarks
> Looking in the mail list archived I found a similar problem reported
march
> 2008
http://n2.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-some
on
> e---tt1815194.html#a1815194
> Was the problem ever fixed, or is this a new problem?
> Thanks
> Gary
> mapguide-users mailing list
View this message in context:
http://n2.nabble.com/Consuming-WFS%2C-error-in-MGE2009-tp2161822p2271495
.html
