[mapguide-users] Consuming WFS, error in MGE2009
isca
mapguide2007 at gmail.com
Wed Feb 4 15:54:48 EST 2009
Unfortunately I never found a solution to this problem. I did succeed to
consume WFS with served by some other servers but in that case some other
problems were occurring (not possible to select features, unstable, ...).
Gary Morin wrote:
> I'm using MGE 2009 and trying to consume a WFS published by Geoserver.
> I'm using Stuido author, create an data connection to the WFS works fine,
> and I can create a layer, but when I attempt to preview the layer no data
> is shown and an error is logged. The same WFS work fine in AutoCAD Map
> 2009
> <2009-01-15T10:15:12> 127.0.0.1 Administrator
> Error: Failed to stylize layer: tiger landmarks
> An exception occurred in FDO component.
> Schema can not be found in the collection.
> StackTrace:
> - MgMappingUtil.StylizeLayers line 786 file
> d:\build\carrera_nightly\build_34.2\ent\os\server\src\services\mapping\Map
> pingUtil.cpp Failed to stylize layer: tiger landmarks
> Looking in the mail list archived I found a similar problem reported march
> 2008
> http://n2.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-someon
> e---tt1815194.html#a1815194
> Was the problem ever fixed, or is this a new problem?
> Thanks
> Gary
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Consuming-WFS%2C-error-in-MGE2009-tp2161822p2271495.html
