[mapguide-users] Connecting to WMS
Stefan Dalakov
s.dalakov at mapware.net
Fri Feb 6 05:05:25 EST 2009
Kenneth, I missed somehow the problem, described by Tom, but I have to
say that Gunter was absolutely right and helpful. I moved the project to
MGOS 1.2 (luckily I have both versions installed) and now it works as
expected.
Thank you !
Stefan
Kenneth Skovhede, GEOGRAF A/S wrote:
> If the problem is as Tom describes, it is likely because Studio uses
> the CSMap coordinate system,
> and MGOS uses Proj.4.
> If you setup an override using Studio, it is invalid for some
> coordinate systems, because they are named
> slightly different in Proj.4.
> Try using Maestro to setup the override, as it uses the server
> coordinate system, regardless of brand what it is.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Gunter Becker skrev:
>> Hi,
>> please have a look at http://trac.osgeo.org/mapguide/ticket/600 trac ticket
>> 600 .
>> I think that is the same problem.
>> Gunter
>> Stefan Dalakov wrote:
>>> Hi Kenneth,
>>> I explored the error log.
>>> The problem is that coordinate systems do not match BUT :
>>> 1. The error log says
>>> /The coordinate system (*EPSG:32633*) of layer RissaWMSLayer1 cannot be
>>> different than the coordinate system (*EPSG:32632*) of the map
>>> /2. The wms layer is configured to use /*EPSG:32632 */- in my config.xml
>>> it is written
>>> / <RasterDefinition name="Image">
>>> <Format>PNG</Format>
>>> <Transparent>true</Transparent>
>>> <BackgroundColor>0xFFFFFF</BackgroundColor>
>>> <Time>current</Time>
>>> <Elevation>0</Elevation>
>>> <SpatialContext>*EPSG:32632*</SpatialContext>
>>> <Layer name="VERANDA">
>>> /3. The service supports this coordinate system - in GetCapabilities
>>> document I have
>>> <SRS>EPSG:32633</SRS>
>>> <BoundingBox SRS="EPSG:32633" minx="218329.98786561"
>>> miny="7160648.90075887" maxx="305197.974972341" maxy="7041546.39019898"/>
>>> *<SRS>EPSG:32632</SRS>
>>> <BoundingBox SRS="**EPSG:32632" minx="506720" miny="7147644"
>>> maxx="604333" maxy="7037305"/>
>>> *<SRS>EPSG:32634</SRS>
>>> <BoundingBox SRS="EPSG:32634" minx="-68103.0343048812"
>>> miny="7200948.9760428" maxx="7352.92691530631" maxy="7073836.91252369"/>
>>> <SRS>EPSG:9804</SRS>
>>> <BoundingBox SRS="EPSG:9804" minx="1017422.41132931"
>>> miny="9427477.01214373" maxx="1234782.60719126" maxy="9172903.66920839"/>
>>> So, I want the map and WMS layer to be in coordinate system *32632*, the
>>> Feature source is configured to use this coordinate system, the service
>>> supports it, but still the server sends the output in *32633.*
>>> Can you spot my mistake ?
>>> Best regards : Stefan Dalakov
>>> /Kenneth Skovhede, GEOGRAF A/S wrote:
>>>> Since a WMS layer is a raster layer, MapGuide requires that the
>>>> Coordinate System of the layer is EXACTLY the same as for the map.
>>>> This means that the Coordinate System Override on the layer must match
>>>> the map's Coordinate System exactly.
>>>> To see if there are any errors reported, look in the error log:
>>>> C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
>>>> Stefan Dalakov skrev:
>>>>> Hi all,
>>>>> I am trying to add a WMS layer to my map.
>>>>> I followed the procedure described here :
>>>>> https://trac.osgeo.org/fdo/wiki/FdoWmsNotes
>>>>> to create a feature source.
>>>>> When I open the feature source in Studio the connection tests OK.
>>>>> Clicking the *Refresh* button generates an error originating from
>>>>> displayschema.php at line :
>>>>> /document.getElementById("Geom_"+"RissaWMS").previousSibling.firstChild.src
>>>>> = "./images/collapse_pane.png";
>>>>> /for each layer in the WMS feature source which is not critical
>>>>> (critical for Studio)
>>>>> *View Data *link then reports BBOX parameter missing, which I assume
>>>>> is normal
>>>>> I create a Layer afterwards, based on this Feature Source. The layer
>>>>> seems ok - refreshes OK, nothing on screen . This I also assume
>>>>> normal as the layers (as described in the GetCapabilities
>>>>> document) are limited to scale ranges up to 1:5000.
>>>>> I add this layer to an existing map, with matching coordinate system
>>>>> (EPSG:32632 of the WMS Feature Source and UTM-WGS84 / Zone 32 North
>>>>> of the map).
>>>>> The WMS layer is not shown on the preview in Studio - perhaps this is
>>>>> also normal - my other raster layers are not previewed either.
>>>>> But when I don't see the layer data in browser I am really stressed.
>>>>> And my biggest stress is based on the fact that I do not know how to
>>>>> debug this situation
>>>>> Any help will be highly appreciated
>>>>> Thank you in advance : Stefan Dalakov
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090206/930798fb/attachment.html
