[mapguide-users] Connect to PostgreSQL database via DNS (Mapguide Studio 2009)
Rui Daniro ruidaniro at hotmail.co.uk
Thu Feb 5 06:09:12 EST 2009
Hi Kenneth,
Thanks for help, but I believe that is not my problem.  As I can see Paulo
problems is to connect to the database, but not my case, I am able to
connect and see the tabular data, the only thing I am not able to do is plot
my geometric data.
Anyway, I did a search on my systems and I could not found those dll's so I
decided copy and past them on the following folder
\MapGuideOpenSource2.0\Server\Bin\FDO . Do they need any customisation?
Thanks again for you time.
Rui
  _____
De: Kenneth Skovhede, GEOGRAF A/S (via Nabble)
[mailto:ml-user+64672-1645459268 at n2.nabble.com]
Enviada: 05 February 2009 07:38
Para: Rui Daniro
Assunto: Re: [mapguide-users] Connect to PostgreSQL database via DNS
Hi Rui.
Please see if this explains your trouble:
http://n2.nabble.com/FDO-OGR-Provider-for-PostGreSQL-8.3-%2B-PostGis-td22700
66.html
Regards, Kenneth Skovhede, GEOGRAF A/S
Rui Daniro skrev:
> Hi all,
> I am using MapGuide Studio 2009 and have a database created using
PostgreSQL
> which I connected to it using via DNS. I tested the connection and I get a
> message saying sucessful connected, then I defined the geometry properties
> and selected the appropiate coordinate system for the table which I want
to
> map. On preview I can see the geometric properties adn data properties,
when
> I select view data I am able to see my table data, but when I select view
> feature nothing happens. I can see the zoom/pan tool and the loading
> animation, but nothing happens, I leave it for ages and nothing comes up.
> Can you help me with this? Can you highlight on this? Thank you in
advance.
> best regards
> Rui
mapguide-users mailing list
mapguide-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2273611&i=0>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
  _____
This email is a reply to your post @
http://n2.nabble.com/Connect-to-PostgreSQL-database-via-DNS-%28Mapguide-Stud
io-2009%29-tp2268432p2273611.html
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Connect-to-PostgreSQL-database-via-DNS-%28Mapguide-Studio-2009%29-tp2268432p2274344.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090205/b7481d95/attachment.html
