[mapguide-users] Connect to PostgreSQL database via DNS (Mapguide
Studio 2009)
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Feb 5 08:16:32 EST 2009
They should work right away.
Do you get any errors in the log files?
The preview feature does not always work, because the data extent is
sometimes reported incorrectly.
Try to create a map, and set the coordinate systems and extent to fit
the layer, then add the layer.
You should now be able to preview the map.
To be certain, try adding a layer with data in the same region that you
know works.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rui Daniro skrev:
> Hi Kenneth,
> Thanks for help, but I believe that is not my problem. As I can see
> Paulo problems is to connect to the database, but not my case, I am
> able to connect and see the tabular data, the only thing I am not able
> to do is plot my geometric data.
> Anyway, I did a search on my systems and I could not found those dll's
> so I decided copy and past them on the following folder
> \MapGuideOpenSource2.0\Server\Bin\FDO . Do they need any customisation?
> Thanks again for you time.
> Rui
> *De:* Kenneth Skovhede, GEOGRAF A/S (via Nabble)
> [mailto:ml-user+64672-1645459268 at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2274344&i=0>]
> *Enviada:* 05 February 2009 07:38
> *Para:* Rui Daniro
> *Assunto:* Re: [mapguide-users] Connect to PostgreSQL database via DNS
> (Mapguide Studio 2009)
> Hi Rui.
> Please see if this explains your trouble:
> http://n2.nabble.com/FDO-OGR-Provider-for-PostGreSQL-8.3-%2B-PostGis-td2270066.html
> Rui Daniro skrev:
> > Hi all,
> > I am using MapGuide Studio 2009 and have a database created using
> PostgreSQL
> > which I connected to it using via DNS. I tested the connection and I
> get a
> > message saying sucessful connected, then I defined the geometry
> properties
> > and selected the appropiate coordinate system for the table which I
> want to
> > map. On preview I can see the geometric properties adn data
> properties, when
> > I select view data I am able to see my table data, but when I select
> view
> > feature nothing happens. I can see the zoom/pan tool and the loading
> > animation, but nothing happens, I leave it for ages and nothing comes
> up.
> > Can you help me with this? Can you highlight on this? Thank you in
> advance.
> > best regards
> > Rui
> mapguide-users mailing list
> mapguide-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2273611&i=0>
> This email is a reply to your post @
> http://n2.nabble.com/Connect-to-PostgreSQL-database-via-DNS-%28Mapguide-Studio-2009%29-tp2268432p2273611.html
> You can reply by email or by visting the link above.
> View this message in context: RE: [mapguide-users] Connect to
> PostgreSQL database via DNS (Mapguide Studio 2009)
> <http://n2.nabble.com/Connect-to-PostgreSQL-database-via-DNS-%28Mapguide-Studio-2009%29-tp2268432p2274344.html>
> Sent from the MapGuide Users mailing list archive
> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090205/5ff7d21e/attachment.html
