[mapguide-users] Programmatically add a layer from SDF
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Feb 5 08:13:31 EST 2009
After creating the SDF FeatureSource, you can use MapGuide to query it:
http://mapguide.osgeo.net/files/mapguide/docs/webapi/d5/d10/class_mg_feature_service_7ca27aeb7ab769babccefd67d1335c34.html#7ca27aeb7ab769babccefd67d1335c34
The results of DescribeSchema() gives you all the schemas/classes
supported by the SDF (yes, it may have many tables).
The MgClass item has a method called GetProperties() which will return
all the avalible columns
in the SDF file, including their type.
Regards, Kenneth Skovhede, GEOGRAF A/S
sekko970 skrev:
> I need to add a new layer to my map with an SDF resource and using an XML
> template layer definition, but I don't know how to extract the name of
> Feature Class and Geometry.
> I'm using .NET WebAPI.
> Could you help me?
> Thanks in advance,
> Fabio
