[mapguide-users] Programmatically add a layer from SDF
Ivan Milicevic Ivan.Milicevic at supranet.hr
Thu Feb 5 08:26:34 EST 2009
Kenneth, is it possible to edit dana in these tables?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Thursday, February 05, 2009 2:14 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Programmatically add a layer from SDF
After creating the SDF FeatureSource, you can use MapGuide to query it:
http://mapguide.osgeo.net/files/mapguide/docs/webapi/d5/d10/class_mg_fea
ture_service_7ca27aeb7ab769babccefd67d1335c34.html#7ca27aeb7ab769babccef
d67d1335c34
The results of DescribeSchema() gives you all the schemas/classes
supported by the SDF (yes, it may have many tables).
The MgClass item has a method called GetProperties() which will return
all the avalible columns
in the SDF file, including their type.
Regards, Kenneth Skovhede, GEOGRAF A/S
sekko970 skrev:
> I need to add a new layer to my map with an SDF resource and using an
XML
> template layer definition, but I don't know how to extract the name of
> Feature Class and Geometry.
> I'm using .NET WebAPI.
> Could you help me?
> Thanks in advance,
> Fabio
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
