[mapguide-users] Programmatically add a layer from SDF
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Feb 5 08:29:00 EST 2009
Yes, just call the "UpdateFeatures" method on an "MgResourceService"
instance.
Regards, Kenneth Skovhede, GEOGRAF A/S
Ivan Milicevic skrev:
> Kenneth, is it possible to edit dana in these tables?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
> Sent: Thursday, February 05, 2009 2:14 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Programmatically add a layer from SDF
> After creating the SDF FeatureSource, you can use MapGuide to query it:
> http://mapguide.osgeo.net/files/mapguide/docs/webapi/d5/d10/class_mg_fea
> ture_service_7ca27aeb7ab769babccefd67d1335c34.html#7ca27aeb7ab769babccef
> d67d1335c34
> The results of DescribeSchema() gives you all the schemas/classes
> supported by the SDF (yes, it may have many tables).
> The MgClass item has a method called GetProperties() which will return
> all the avalible columns
> in the SDF file, including their type.
> sekko970 skrev:
>> I need to add a new layer to my map with an SDF resource and using an
> XML
>> template layer definition, but I don't know how to extract the name of
>> Feature Class and Geometry.
>> I'm using .NET WebAPI.
>> Could you help me?
>> Thanks in advance,
>> Fabio
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090205/db2355eb/attachment.html
