[mapguide-users] Working with state plane data in Mapguide studio
Andy Morsell
amorsell at spatialgis.com
Thu Feb 5 17:58:08 EST 2009
It's probably a coordinate system issue. Have you assigned the proper
coordinate system to the DWG project itself as well as specify it when you
export? Which version of Autodesk Map are you using? Are you using the
Map->Tools->Export to Autodesk MapGuide option or are you using the Publish
to MapGuide option?
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of clarkie342
Sent: Thursday, February 05, 2009 2:25 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Working with state plane data in Mapguide studio
I have some data in State Plane coordinate system (AL83-EF) in a AutoCAD
dwg.
I exported this data to SDF and opened in Mapguide Stuiod, data does not
show up in the layer preview.
Exporting it to shp and opening it in Arcmap works fine. Any ideas?
Thanks.
View this message in context:
http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp2277
697p2277697.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
