[mapguide-users] Working with state plane data in Mapguide studio
clarkie342
f2000342 at gmail.com
Thu Feb 5 18:12:48 EST 2009
I am using Autodesk 2009. so its File->Convert DWG to Autodesk SDF option.
Publish to mapguide option seems to create dwf instead of SDF. I need sdf.
The coordinate system seems to be ok since it works well with shp in Arcmap.
It is assigned and the right coordinate system is detected during the
export.
Here is a sample sdf. Thanks.
Andy Morsell wrote:
> It's probably a coordinate system issue. Have you assigned the proper
> coordinate system to the DWG project itself as well as specify it when you
> export? Which version of Autodesk Map are you using? Are you using the
> Map->Tools->Export to Autodesk MapGuide option or are you using the
> Publish
> to MapGuide option?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of clarkie342
> Sent: Thursday, February 05, 2009 2:25 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Working with state plane data in Mapguide studio
> I have some data in State Plane coordinate system (AL83-EF) in a AutoCAD
> dwg.
> I exported this data to SDF and opened in Mapguide Stuiod, data does not
> show up in the layer preview.
> Exporting it to shp and opening it in Arcmap works fine. Any ideas?
> Thanks.
> http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp2277
> 697p2277697.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/file/n2278016/boundary.zip boundary.zip
View this message in context: http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp2277697p2278016.html
