[mapguide-users] Working with state plane data in Mapguide studio
Mark Pendergraft
markp at Meadgilman.com
Thu Feb 5 18:23:38 EST 2009
Odd, that file shows no features in Civil 3D or in MapGuide Studio 2009.
What do you see when you open it in ArcMap?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of clarkie342
Sent: Thursday, February 05, 2009 3:13 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Working with state plane data in Mapguide
studio
I am using Autodesk 2009. so its File->Convert DWG to Autodesk SDF
option.
Publish to mapguide option seems to create dwf instead of SDF. I need
sdf.
The coordinate system seems to be ok since it works well with shp in
Arcmap.
It is assigned and the right coordinate system is detected during the
export.
Here is a sample sdf. Thanks.
Andy Morsell wrote:
> It's probably a coordinate system issue. Have you assigned the proper
> coordinate system to the DWG project itself as well as specify it when
you
> export? Which version of Autodesk Map are you using? Are you using
the
> Map->Tools->Export to Autodesk MapGuide option or are you using the
> Publish
> to MapGuide option?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
clarkie342
> Sent: Thursday, February 05, 2009 2:25 PM
> Subject: [mapguide-users] Working with state plane data in Mapguide
studio
> I have some data in State Plane coordinate system (AL83-EF) in a
AutoCAD
> dwg.
> I exported this data to SDF and opened in Mapguide Stuiod, data does
not
> show up in the layer preview.
> Exporting it to shp and opening it in Arcmap works fine. Any ideas?
> Thanks.
http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp
2277
> 697p2277697.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/file/n2278016/boundary.zip boundary.zip
2277697p2278016.html
