[mapguide-users] Fusion raise AJAX Error,  Was: Repository or
	server error
    Rodolfo Moreno
    rmoreno at voxiva.com
    Fri Feb  6 10:47:56 EST 2009
This is the error that FUSION is raised:
Windows Internet Explorer
Fusion Error:
WARNING: Exception occurred in AJAX callback.
Message: Array length must be a finite positive integer
Response:
{sessionId:'7913cd3a-0000-1000-8000-001cc06b0cf3_en_7F0000010AFC0AFB0AFA',mapId:'Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition',metersPerUnit:111319.4908,mapTitle:'Sheboygan',mapName:'Sheboygan498c585d92817',extent:[-87.764986990963,43.691398128788,-87.6955215109,43.79752000048],layers:[{propertyMappings:{},uniqueId:'79863d5c-0000-1000-8004-001cc06b0cf3',layerName:'Roads',layerTypes:[1],displayInLegend:true,expandInLegend:true,resourceId:'Library://Samples/Sheboygan/Layers/Roads.LayerDefinition',parentGroup:'79863d5c-0000-1000-8003-001cc06b0cf3',legendLabel:'Roads',selectable:false,visible:true,actuallyVisible:true,editable:false,scaleRanges:
[{minScale:0,maxScale:10000,styles:[{legendLabel:'',filter:'',geometryType:2,categoryIndex:0}]},{minScale:10000,maxScale:24000,styles:[{legendLabel:'',filter:'',geometryType:2,categoryIndex:0}]}]},{propertyMappings:{},uniqueId:'79863d5c-0000-1000-8005-001cc06b0cf3',layerName:'Rail
Lines',layerTypes:[1],displayInLegend:true,expandInLegend:true,resourceId:'Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition',parentGroup:'79863d5c-0000-1000-8003-001cc06b0cf3',legendLabel:'Rail
Lines',selectable:false,visible:false,actuallyVisible:false,editable:false,scaleRanges:
[{minScale:0,maxScale:24000,styles:[{legendLabel:'',filter:'',geometryType:2,categoryIndex:0}]}]},{propertyMappings:{},uniqueId:'79863d5c-0000-1000-8006-001cc06b0cf3',layerName:'Districts',layerTypes:[2],displayInLegend:true,expandInLegend:true,resourceId:'Library://Samples/Sheboygan/Layers/Districts.LayerDefinition',parentGroup:'79863d5c-0000-1000-8002-001cc06b0cf3',legendLabel:'Districts',selectable:true,visible:true,actuallyVisible:false,editable:false,scaleRanges:
[{minScale:10000,maxScale:'infinity',styles:[{legendLabel:'',filter:'',geometryType:3,categoryIndex:0}]}]},{propertyMappings:{},uni…
OK
Cheers,
Kenneth Skovhede, GEOGRAF A/S wrote:
> AFAIK, the Fusion error is in javascript, and thus no log entry is
> created.
> I don't know enough about Fusion to determine what may have caused the
> error.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Rodolfo Moreno skrev:
>> Thanks Kenneth, I was a silly I forgot to review the log file.
>> this is the error in the log file.
>> Error: An exception occurred in FDO component.
>>         RDBMS: No current open database.
>> The error is being raised by feature sources with feature joins to SQL
>> 2008
>> (my trial version has expired).
>> Describing the problem:
>> - Municipalities.FeatureSource has 2 featsources:
>> - Municipalities and MunicipalitiesExtension (It has featurejoins).
>> - Layer1 uses Municipalities (not MunicipalitiesExtension)
>> - Layer1 is used in Map1, then Map1 raise the RDBMS error.
>> I thought that only in the case that MunicipalitiesExtension is used the
>> error would be raised (although I guess that it should be like I was
>> thought)
>> I guess that it solved my problem, However I don't how why some of my
>> maps
>> don't work well, even if these are not using layers with feature joins.
>> For
>> example before that the expiration date of my SQL, these maps worked good
>> in
>> both IE7 and FF2, and now these maps only are work good in FF2 and not in
>> IE7.
>> It's happennig with Fusion 1.0.6 (raise AJAX ERROR) and in the mapguide
>> log
>> any error is registered. the ajax viewer is working good in both
>> browsers.
>> I am really confused, could the SQL expiration has generated the FUSION
>> error?
>> Regards,
>>> What does the error log state:
>>> C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
>>> If you can create a MapGuide Package, you can do this:
>>> 1. Create MapGuide Package
>>> 2. Move the package outside the install dir.
>>> 3. Uninstall MapGuide
>>> 4. Delete the installation folder
>>> 5. Re-install MapGuide
>>> 6. Restore the package
>>> That should clear any corruption in the repository.
>>> I doubt that the repository is the problem though.
>>>> Hi all,
>>>> I am having an odd issue.
>>>> the problem consists in that the server doesn't send the maps how if
>>>> these
>>>> did not exist, however when I access to my repository by Maestro or
>>>> Studio2009 I can see and edit all the resources of my repository.
>>>> the events before that the server or repository started to fail are:
>>>> - I was editing my resources using mapguide maestro and mapguide studio
>>>> 2009
>>>> at the same time.
>>>> - My SQL 2008 trial version has expired today (some of my datasources
>>>> are
>>>> stored there). But I have tested another map that doesn't use data from
>>>> SQL
>>>> and the application doesn't work.
>>>> current efects:
>>>> - the majority of the times the applications(using these resources)
>>>> don't
>>>> work but sometimes these work. (very odd).
>>>> I have restarted the server twice and the error keep on. I guees that
>>>> for
>>>> some reason the repository has been corrupted. So I was looking for a
>>>> tool
>>>> that allows to repair the repository in REPOSITORYADMIN directory
>>>> without
>>>> successful, becuase the tools within of that directory are for
>>>> restoring.
>>>> or maybe it to be a server error?
>>>> any help will be appreciated,
>>>> Rodolfo Moreno
>>>> CivilEng
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Rodolfo Moreno
>> CivilEng
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Repository-or-server-error-tp2265645p2284781.html
