[mapguide-users] MapGuide Programming using C#, need help, please
Jonio, Dennis (Aviation)
DJonio at miami-airport.com
Tue Feb 10 09:22:06 EST 2009
I have not a clue what you are doing with it later but just change the
line to this ...
MgLayerBase layer = map.GetLayers().GetItem("Parcels");
BTW ... it is NOT Mglayer it is MgLayer
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of staniz
Sent: Tuesday, February 10, 2009 9:11 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MapGuide Programming using C#, need help,
please
Thanks for comments.
I have tried to modify by adding (MgLayer) to DisplayQueryResult.aspx
---MgLayer layer = (Mglayer)map.GetLayers().GetItem("Parcels");--- ,
but no result coming after pushing the Submit Query Button .
regards
Staniz
staniz wrote:
> I am using MGE Server and Studio 2008, windows XP and IIS 5.1. I
> downloaded sample code from
http://download.autodesk.com/media/adn/DevTV_%20Introduction_to_MGE_Prog
ramming/SampleCode.zip
> these code is recommended for MGE2007, but I think its also work for
> MGE2008.
> I followed all the instruction in video, and ran the default.aspx. Its
> worked by but When I was trying to run the Query.aspx and execute the
> DisplayQueryResult.aspx I got the following error:
> Compiler Error Message : CS0266:
> cannot implicitly convert type
> `OSGeo.Mapguide.MgLayerBase` to
> `OSGeo.Mapguide.MgLayer`. An explicit
> conversion exist (are you missing a cast?)
> Source code:
> Line 58: MgLayer layer =map.Getlayer().GetItem("Parcels");
> .Net framwork Version:2.0.50727.42
> please help to solve this problem...
> thanks is advance.
> staniz
View this message in context:
http://n2.nabble.com/MapGuide-Programming-using-C-%2C-need-help%2C-pleas
e-tp2301814p2302724.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
E-mails are automatically scanned for viruses using McAfee.
