[mapguide-users] How to Highlight Line Features
padmini godavarthi
godavarthi.padmini at gmail.com
Wed Feb 11 03:43:38 EST 2009
iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
Now iam struck up with high lighting line features on the map.
my code is as follows:-
Dim fetresource1 As MgResourceIdentifier = New
MgResourceIdentifier("Library://WaterNetwork/data/resource.FeatureSource")
Dim nameQuery1 As MgFeatureQueryOptions = New
MgFeatureQueryOptions()
Dim val1 As String = "STARTVALVE"
nameQuery1.AddFeatureProperty(val1)
nameQuery1.SetFilter("STARTVALVE ='124'")
Dim layer1 As MgLayer = map.GetLayers().GetItem("waterpipe")
layer1.Selectable = True
Dim featureReader1 As MgFeatureReader =
featureService.SelectFeatures(fetresource1, layer1.GetFeatureClassName(),
nameQuery1)
Dim selection As MgSelection = New MgSelection(map)
selection.AddFeatures(layer1, featureReader1, 0)
Dim selectXML As String = selection.ToXml()
selection.Save(resourceService, "watermap")
Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
"select('" & selectXML & "')", True)
map.Save(resourceService)
featureReader1.Close()
function select(val) {
var selectionXML = val;
parent.parent.SetSelectionXML(selectionXML);
alert("Selected");
parent.parent.refresh;
but the line feature is not highlighting ? but this code works with
polygon feature.
i found that in xml
<?xml version="1.0" encoding="UTF-8"?><FeatureSet
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
id="1f6baf1e-0000-1000-8000-0016e692a356"> <Class
id="KingOra:IMCN~GIS_WATERPIPE_DETAILS~SHAPE"> <ID></ID> <ID></ID>
</Class> </Layer></FeatureSet>
ID doesn't came.is there problem with ID?
Can u plz tell me the solution?
Thanks and Regards,
Padmini
View this message in context: http://n2.nabble.com/How-to-Highlight-Line-Features-tp2307466p2307466.html
