[mapguide-users] How to Highlight Line Features
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Feb 12 03:00:32 EST 2009
I think your data has broken primary keys (eg. empty strings as primary
key).
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
> Now iam struck up with high lighting line features on the map.
> my code is as follows:-
> Dim fetresource1 As MgResourceIdentifier = New
> MgResourceIdentifier("Library://WaterNetwork/data/resource.FeatureSource")
> Dim nameQuery1 As MgFeatureQueryOptions = New
> MgFeatureQueryOptions()
> Dim val1 As String = "STARTVALVE"
> nameQuery1.AddFeatureProperty(val1)
> nameQuery1.SetFilter("STARTVALVE ='124'")
> Dim layer1 As MgLayer = map.GetLayers().GetItem("waterpipe")
> layer1.Selectable = True
> Dim featureReader1 As MgFeatureReader =
> featureService.SelectFeatures(fetresource1, layer1.GetFeatureClassName(),
> nameQuery1)
> Dim selection As MgSelection = New MgSelection(map)
> selection.AddFeatures(layer1, featureReader1, 0)
> Dim selectXML As String = selection.ToXml()
> selection.Save(resourceService, "watermap")
> Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
> "select('" & selectXML & "')", True)
> map.Save(resourceService)
> featureReader1.Close()
> function select(val) {
> var selectionXML = val;
> parent.parent.SetSelectionXML(selectionXML);
> alert("Selected");
> parent.parent.refresh;
> but the line feature is not highlighting ? but this code works with
> polygon feature.
> i found that in xml
> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
> id="1f6baf1e-0000-1000-8000-0016e692a356"> <Class
> id="KingOra:IMCN~GIS_WATERPIPE_DETAILS~SHAPE"> <ID></ID> <ID></ID>
> </Class> </Layer></FeatureSet>
> ID doesn't came.is there problem with ID?
> Can u plz tell me the solution?
> Thanks and Regards,
> Padmini
