[mapguide-users] How to Highlight Line Features
padmini godavarthi godavarthi.padmini at gmail.com
Thu Feb 12 03:47:22 EST 2009
In my table iam not having any primary key columns.
Thanks and Regards,
Padmini
Kenneth Skovhede, GEOGRAF A/S wrote:
> I think your data has broken primary keys (eg. empty strings as primary
> key).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>>   Hi,
>> iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>> Now iam struck up with high lighting line features on the map.
>> my code is as follows:-
>>     Dim fetresource1 As MgResourceIdentifier = New
>> MgResourceIdentifier("Library://WaterNetwork/data/resource.FeatureSource")
>>         Dim nameQuery1 As MgFeatureQueryOptions = New
>> MgFeatureQueryOptions()
>>         Dim val1 As String = "STARTVALVE"
>>         nameQuery1.AddFeatureProperty(val1)
>>               nameQuery1.SetFilter("STARTVALVE ='124'")
>>         Dim layer1 As MgLayer = map.GetLayers().GetItem("waterpipe")
>>         layer1.Selectable = True
>>         Dim featureReader1 As MgFeatureReader =
>> featureService.SelectFeatures(fetresource1, layer1.GetFeatureClassName(),
>> nameQuery1)
>>         Dim selection As MgSelection = New MgSelection(map)
>>         selection.AddFeatures(layer1, featureReader1, 0)
>>         Dim selectXML As String = selection.ToXml()
>>         selection.Save(resourceService, "watermap")
>>         Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
>> "select('" & selectXML & "')", True)
>>         map.Save(resourceService)
>>         featureReader1.Close()
>> function select(val) {
>>          var selectionXML = val;
>>           parent.parent.SetSelectionXML(selectionXML);
>>                  alert("Selected");
>>       parent.parent.refresh;
>> but the line  feature is not highlighting ?  but this code works with
>> polygon feature.
>> i  found that in xml
>> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
>> id="1f6baf1e-0000-1000-8000-0016e692a356">  <Class
>> id="KingOra:IMCN~GIS_WATERPIPE_DETAILS~SHAPE">   <ID></ID>   <ID></ID>
>> </Class> </Layer></FeatureSet>
>> ID doesn't came.is there problem with ID?
>> Can u plz tell me the solution?
>> Thanks and Regards,
>> Padmini
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/How-to-Highlight-Line-Features-tp2307466p2313727.html
