[mapguide-users] How to Highlight Line Features
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Feb 12 04:58:44 EST 2009
You cannot use selection if the table does not have unique primary keys.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> In my table iam not having any primary key columns.
> Thanks and Regards,
> Padmini
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I think your data has broken primary keys (eg. empty strings as primary
>> key).
>>> Hi,
>>> iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>> Now iam struck up with high lighting line features on the map.
>>> my code is as follows:-
>>> Dim fetresource1 As MgResourceIdentifier = New
>>> MgResourceIdentifier("Library://WaterNetwork/data/resource.FeatureSource")
>>> Dim nameQuery1 As MgFeatureQueryOptions = New
>>> MgFeatureQueryOptions()
>>> Dim val1 As String = "STARTVALVE"
>>> nameQuery1.AddFeatureProperty(val1)
>>> nameQuery1.SetFilter("STARTVALVE ='124'")
>>> Dim layer1 As MgLayer = map.GetLayers().GetItem("waterpipe")
>>> layer1.Selectable = True
>>> Dim featureReader1 As MgFeatureReader =
>>> featureService.SelectFeatures(fetresource1, layer1.GetFeatureClassName(),
>>> nameQuery1)
>>> Dim selection As MgSelection = New MgSelection(map)
>>> selection.AddFeatures(layer1, featureReader1, 0)
>>> Dim selectXML As String = selection.ToXml()
>>> selection.Save(resourceService, "watermap")
>>> Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
>>> "select('" & selectXML & "')", True)
>>> map.Save(resourceService)
>>> featureReader1.Close()
>>> function select(val) {
>>> var selectionXML = val;
>>> parent.parent.SetSelectionXML(selectionXML);
>>> alert("Selected");
>>> parent.parent.refresh;
>>> but the line feature is not highlighting ? but this code works with
>>> polygon feature.
>>> i found that in xml
>>> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
>>> id="1f6baf1e-0000-1000-8000-0016e692a356"> <Class
>>> id="KingOra:IMCN~GIS_WATERPIPE_DETAILS~SHAPE"> <ID></ID> <ID></ID>
>>> </Class> </Layer></FeatureSet>
>>> ID doesn't came.is there problem with ID?
>>> Can u plz tell me the solution?
>>> Thanks and Regards,
>>> Padmini
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090212/3594b8fd/attachment.html
