[mapguide-users] Fusion javascript (phpviewersample)
Mike Adair madair at dmsolutions.ca
Thu Feb 12 16:50:09 EST 2009
Fusion 2.0 beta is reasonably stable for most the functionality that was
in the 1.1 series of releases.  The biggest change is that a <MapGroup>
element now allows multiple  <Map> elements which can be of any layer
type supported by OpenLayers, and this is the part that needs more
testing.  We will be documenting how to configure that section soon, but
the MapGuide standard template includes examples of including WMS and
Google layers.
It also uses a new version of Jx based on MooTools rather than the old
Prototype version but most of the differences there will be in the CSS
for the application.  Fusion 2.0 also switches to using OpenLayers
vector rendering in place of the excanvas implementation, and I haven't
seen any showstopper bugs because of that change yet.
Mike
Jason Birch wrote:
> It's beta, which means it's been tried by the developers but not much
> more.
> >From my experience, it is very important to invest the time to test
> software while it is in beta form.  It is impossible for developers to
> know how you will use the software.  If you don't use it in beta, there
> is a strong likelihood that your use of the released product will run
> into bugs.
> Problems found in the release version may be fixed with a point-release,
> but not with any urgency unless they affect a large number of users.
> If you want stable release software for your use, then you need to test
> it when it's in beta (or earlier).
> Jason
> -----Original Message-----
> From: Franco Caloni
> Sent: February-12-09 10:30 AM
> To: 'MapGuide Users Mail List'
> Subject: R: [mapguide-users] Fusion javascript (phpviewersample)
> I saw it, but: how much is stable?
> I can try to use it but I would like to know it before :)
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
