[mapguide-users] How to Highlight Line Features
padmini godavarthi godavarthi.padmini at gmail.com
Fri Feb 13 05:29:50 EST 2009
is selection is done based on primary key of type integer?
Then in my table there is no primary key column.How can i achieve thin?
Thanks and Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> It is not enough that it has unique values, there must be a primary key
> defined.
> Since you are using Oracle, the key must be defined on the Oracle table.
> IIRC, the primary key must also be of type integer.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> In my table STARTVALVE has unique valves .By using that "STARTVALVE"
>> property iam trying for selection .
>> Regards,
>> Padmini.
>>> You cannot use selection if the table does not have unique primary keys.
>>>> Hi,
>>>> In my table iam not having any primary key columns.
>>>> Thanks and Regards,
>>>> Padmini
>>>>> I think your data has broken primary keys (eg. empty strings as
>>>>> primary
>>>>> key).
>>>>>>   Hi,
>>>>>> iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>> Now iam struck up with high lighting line features on the map.
>>>>>> my code is as follows:-
>>>>>>     Dim fetresource1 As MgResourceIdentifier = New
>>>>>> MgResourceIdentifier("Library://WaterNetwork/data/resource.FeatureSource")
>>>>>>         Dim nameQuery1 As MgFeatureQueryOptions = New
>>>>>> MgFeatureQueryOptions()
>>>>>>         Dim val1 As String = "STARTVALVE"
>>>>>>         nameQuery1.AddFeatureProperty(val1)
>>>>>>               nameQuery1.SetFilter("STARTVALVE ='124'")
>>>>>>         Dim layer1 As MgLayer = map.GetLayers().GetItem("waterpipe")
>>>>>>         layer1.Selectable = True
>>>>>>         Dim featureReader1 As MgFeatureReader =
>>>>>> featureService.SelectFeatures(fetresource1,
>>>>>> layer1.GetFeatureClassName(),
>>>>>> nameQuery1)
>>>>>>         Dim selection As MgSelection = New MgSelection(map)
>>>>>>         selection.AddFeatures(layer1, featureReader1, 0)
>>>>>>         Dim selectXML As String = selection.ToXml()
>>>>>>         selection.Save(resourceService, "watermap")
>>>>>>         Page.ClientScript.RegisterStartupScript(Page.GetType(),
>>>>>> "test",
>>>>>> "select('" & selectXML & "')", True)
>>>>>>         map.Save(resourceService)
>>>>>>         featureReader1.Close()
>>>>>> function select(val) {
>>>>>>          var selectionXML = val;
>>>>>>           parent.parent.SetSelectionXML(selectionXML);
>>>>>>                  alert("Selected");
>>>>>>       parent.parent.refresh;
>>>>>> but the line  feature is not highlighting ?  but this code works with
>>>>>> polygon feature.
>>>>>> i  found that in xml
>>>>>> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
>>>>>> id="1f6baf1e-0000-1000-8000-0016e692a356">  <Class
>>>>>> id="KingOra:IMCN~GIS_WATERPIPE_DETAILS~SHAPE">   <ID></ID>
>>>>>> <ID></ID>
>>>>>> </Class> </Layer></FeatureSet>
>>>>>> ID doesn't came.is there problem with ID?
>>>>>> Can u plz tell me the solution?
>>>>>> Thanks and Regards,
>>>>>> Padmini
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/How-to-Highlight-Line-Features-tp2307466p2320554.html
