[mapguide-users] How to Highlight Line Features
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Feb 13 05:33:39 EST 2009
This is what I found from a quick search:
http://www.techonthenet.com/oracle/primary_keys.php
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> is selection is done based on primary key of type integer?
> Then in my table there is no primary key column.How can i achieve thin?
> Thanks and Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> It is not enough that it has unique values, there must be a primary key
>> defined.
>> Since you are using Oracle, the key must be defined on the Oracle table.
>> IIRC, the primary key must also be of type integer.
>>> Hi,
>>> In my table STARTVALVE has unique valves .By using that "STARTVALVE"
>>> property iam trying for selection .
>>> Regards,
>>> Padmini.
>>>> You cannot use selection if the table does not have unique primary keys.
>>>>> Hi,
>>>>> In my table iam not having any primary key columns.
>>>>> Thanks and Regards,
>>>>> Padmini
>>>>>> I think your data has broken primary keys (eg. empty strings as
>>>>>> primary
>>>>>> key).
>>>>>>> Hi,
>>>>>>> iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>> Now iam struck up with high lighting line features on the map.
>>>>>>> my code is as follows:-
>>>>>>> Dim fetresource1 As MgResourceIdentifier = New
>>>>>>> MgResourceIdentifier("Library://WaterNetwork/data/resource.FeatureSource")
>>>>>>> Dim nameQuery1 As MgFeatureQueryOptions = New
>>>>>>> MgFeatureQueryOptions()
>>>>>>> Dim val1 As String = "STARTVALVE"
>>>>>>> nameQuery1.AddFeatureProperty(val1)
>>>>>>> nameQuery1.SetFilter("STARTVALVE ='124'")
>>>>>>> Dim layer1 As MgLayer = map.GetLayers().GetItem("waterpipe")
>>>>>>> layer1.Selectable = True
>>>>>>> Dim featureReader1 As MgFeatureReader =
>>>>>>> featureService.SelectFeatures(fetresource1,
>>>>>>> layer1.GetFeatureClassName(),
>>>>>>> nameQuery1)
>>>>>>> Dim selection As MgSelection = New MgSelection(map)
>>>>>>> selection.AddFeatures(layer1, featureReader1, 0)
>>>>>>> Dim selectXML As String = selection.ToXml()
>>>>>>> selection.Save(resourceService, "watermap")
>>>>>>> Page.ClientScript.RegisterStartupScript(Page.GetType(),
>>>>>>> "test",
>>>>>>> "select('" & selectXML & "')", True)
>>>>>>> map.Save(resourceService)
>>>>>>> featureReader1.Close()
>>>>>>> function select(val) {
>>>>>>> var selectionXML = val;
>>>>>>> parent.parent.SetSelectionXML(selectionXML);
>>>>>>> alert("Selected");
>>>>>>> parent.parent.refresh;
>>>>>>> but the line feature is not highlighting ? but this code works with
>>>>>>> polygon feature.
>>>>>>> i found that in xml
>>>>>>> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
>>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>>> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
>>>>>>> id="1f6baf1e-0000-1000-8000-0016e692a356"> <Class
>>>>>>> id="KingOra:IMCN~GIS_WATERPIPE_DETAILS~SHAPE"> <ID></ID>
>>>>>>> <ID></ID>
>>>>>>> </Class> </Layer></FeatureSet>
>>>>>>> ID doesn't came.is there problem with ID?
>>>>>>> Can u plz tell me the solution?
>>>>>>> Thanks and Regards,
>>>>>>> Padmini
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090213/09d30a40/attachment.html
