[mapguide-users] How to Highlight Line Features
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Feb 13 08:08:37 EST 2009
Have you restarted the MapGuide server after changing the database schema?
Have you tried to create a new FeatureSource?
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> I attached primary key as "OBJECTID" in my table
> then i want to select the line feature based on this objectid.
> My code is as follows
>         Dim fetresource1 As MgResourceIdentifier = New
> MgResourceIdentifier("Library://WaterNetwork/data/resource.FeatureSource")
>         Dim nameQuery1 As MgFeatureQueryOptions = New
> MgFeatureQueryOptions()
>                nameQuery1.AddFeatureProperty(val1)
>         nameQuery1.SetFilter("OBJECTID =20")
>         Dim layer1 As MgLayer = map.GetLayers().GetItem("waterpipe")
>              Dim value As String = ""
>         Dim featureReader1 As MgFeatureReader =
> featureService.SelectFeatures(fetresource1, layer1.GetFeatureClassName(),
> nameQuery1)
>         While featureReader1.ReadNext()
>             Dim propertyType As Integer =
> featureReader1.GetPropertyType("OBJECTID")
>             value = GetFeaturePropertyValue(featureReader1, "OBJECTID")
>         End While
>         Dim selection As MgSelection = New MgSelection(map)
>         selection.AddFeatures(layer1, featureReader1, 0)
>         Dim selectXML As String = selection.ToXml()
>         selection.Save(resourceService, "watermap")
>         Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
> "select('" & selectXML & "')", True)
>         map.Save(resourceService)
>         featureReader1.Close()
> then after executing this code non of the line was selected.
> Has any idea on it?
> Thanks and Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> This is what I found from a quick search:
>> http://www.techonthenet.com/oracle/primary_keys.php
>>> Hi,
>>> is selection is done based on primary key of type integer?
>>> Then in my table there is no primary key column.How can i achieve thin?
>>> Thanks and Regards,
>>> Padmini.
>>>> It is not enough that it has unique values, there must be a primary key
>>>> defined.
>>>> Since you are using Oracle, the key must be defined on the Oracle table.
>>>> IIRC, the primary key must also be of type integer.
>>>>> Hi,
>>>>> In my table STARTVALVE has unique valves .By using that "STARTVALVE"
>>>>> property iam trying for selection .
>>>>> Regards,
>>>>> Padmini.
>>>>>> You cannot use selection if the table does not have unique primary
>>>>>> keys.
>>>>>>> Hi,
>>>>>>> In my table iam not having any primary key columns.
>>>>>>> Thanks and Regards,
>>>>>>> Padmini
>>>>>>>> I think your data has broken primary keys (eg. empty strings as
>>>>>>>> primary
>>>>>>>> key).
>>>>>>>>>   Hi,
>>>>>>>>> iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>>>> Now iam struck up with high lighting line features on the map.
>>>>>>>>> my code is as follows:-
>>>>>>>>>         Dim val1 As String = "STARTVALVE"
>>>>>>>>>               nameQuery1.SetFilter("STARTVALVE ='124'")
>>>>>>>>>         layer1.Selectable = True
>>>>>>>>> nameQuery1)
>>>>>>>>> "test",
>>>>>>>>> function select(val) {
>>>>>>>>>          var selectionXML = val;
>>>>>>>>>           parent.parent.SetSelectionXML(selectionXML);
>>>>>>>>>                  alert("Selected");
>>>>>>>>>       parent.parent.refresh;
>>>>>>>>> but the line  feature is not highlighting ?  but this code works
>>>>>>>>> with
>>>>>>>>> polygon feature.
>>>>>>>>> i  found that in xml
>>>>>>>>> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
>>>>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>>>>> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
>>>>>>>>> id="1f6baf1e-0000-1000-8000-0016e692a356">  <Class
>>>>>>>>> id="KingOra:IMCN~GIS_WATERPIPE_DETAILS~SHAPE">   <ID></ID>
>>>>>>>>> <ID></ID>
>>>>>>>>> </Class> </Layer></FeatureSet>
>>>>>>>>> ID doesn't came.is there problem with ID?
>>>>>>>>> Can u plz tell me the solution?
>>>>>>>>> Thanks and Regards,
>>>>>>>>> Padmini
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090213/164970af/attachment.html
