[mapguide-users] asp.net example of loading a webmapservice layer
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Feb 16 03:07:31 EST 2009
The API is the same for .Net.
If you remove all the $ signs, it should be easy to convert to .Net.
If you post the snip of code here, perhaps someone will show you how to
do it.
A layer interaction example in .Net, using the MaestroAPI can be found here:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/ModifyLayerFilter
Regards, Kenneth Skovhede, GEOGRAF A/S
stoff skrev:
> Hi, the devGuide gives an example of adding layers to a map in php.
> Has anybody an *comparable example in asp.net*? I want to load an
> ogc-wms into the map by loading an existing layer.definition.xml to a
> resource and add the resource to the map. The xml-file can by
> generated for example by the mapguide studio ... Thanks a lot, stoff
> View this message in context: asp.net example of loading a
> webmapservice layer
> <http://n2.nabble.com/asp.net-example-of-loading-a-webmapservice-layer-tp2328300p2328300.html>
> Sent from the MapGuide Users mailing list archive
> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090216/2f971557/attachment.html
