[mapguide-users] asp.net example of loading a webmapservice layer
Dave Wilson dave.wilson at autodesk.com
Tue Feb 17 15:35:32 EST 2009
I'm not a coder per se, but if your code sample is small enough the following page might give you a good starting point:
http://www.me-u.com/php-asp/
It converts php script to asp .NET. Of course I assume you will have a fair bit of debugging to do after the fact, but it might do most of the major syntax leaps for you.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Monday, February 16, 2009 1:08 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] asp.net example of loading a webmapservice layer
The API is the same for .Net.
If you remove all the $ signs, it should be easy to convert to .Net.
If you post the snip of code here, perhaps someone will show you how to do it.
A layer interaction example in .Net, using the MaestroAPI can be found here:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/ModifyLayerFilter
Regards, Kenneth Skovhede, GEOGRAF A/S
stoff skrev:
Hi, the devGuide gives an example of adding layers to a map in php. Has anybody an comparable example in asp.net? I want to load an ogc-wms into the map by loading an existing layer.definition.xml to a resource and add the resource to the map. The xml-file can by generated for example by the mapguide studio ... Thanks a lot, stoff
View this message in context: asp.net example of loading a webmapservice layer<http://n2.nabble.com/asp.net-example-of-loading-a-webmapservice-layer-tp2328300p2328300.html>
Sent from the MapGuide Users mailing list archive<http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090217/338851d8/attachment.html
