[mapguide-users] Get and edit coordinates of object
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Feb 16 03:12:24 EST 2009
What do you mean by "I get the object"?
If you have the object, there should be some sort of "GetCoordinates" call.
If you want to perform interactive edits of objects in the browser,
try to look at the OpenLayers samples:
http://openlayers.org/dev/examples/modify-feature.html
Fusion is built on OpenLayers, so you can use the same approach with
"Flexible Layouts".
Regards, Kenneth Skovhede, GEOGRAF A/S
Matteo skrev:
> Hi,
>   I need to get and edit the coordinates of a selected object. In the code I
> get the object from current selection but i don't know how get the
> coordinates and edit (move/insert/delete point of line object)
> Thanks
> Matteo
