[mapguide-users] Get and edit coordinates of object
Matteo
matteo.conte1979 at libero.it
Wed Feb 18 08:04:45 EST 2009
Thank you very much
Regards
Matteo
Kenneth Skovhede, GEOGRAF A/S wrote:
> What do you mean by "I get the object"?
> If you have the object, there should be some sort of "GetCoordinates"
> call.
> If you want to perform interactive edits of objects in the browser,
> try to look at the OpenLayers samples:
> http://openlayers.org/dev/examples/modify-feature.html
> Fusion is built on OpenLayers, so you can use the same approach with
> "Flexible Layouts".
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Matteo skrev:
>> Hi,
>> I need to get and edit the coordinates of a selected object. In the
>> code I
>> get the object from current selection but i don't know how get the
>> coordinates and edit (move/insert/delete point of line object)
>> Thanks
>> Matteo
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Get-and-edit-coordinates-of-object-tp2327414p2346726.html
