[mapguide-users] Ora error when displaying layer from view
marius.360
marius at osssa.co.za
Mon Feb 16 07:29:46 EST 2009
Hi All
I have created a layer that reads from an oracle view with a geometry
column. This view has an entry in the USER_SDO_GEOM_METADATA, as well as a
primary key. It is a point layer that displays perfectly in Mapguide 6.5,
but when I turn the layer on in mapguide opensource, it doesn't display and
the following error is logged in the error logs:
<2009-02-16T14:09:43> 192.168.0.55 Anonymous
Error: Failed to stylize layer: NEURON_PROP
An exception occurred in FDO component.
ORA-00923: FROM keyword not found where expected
StackTrace:
- MgMappingUtil.StylizeLayers line 786 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\mapping\MappingUtil.cpp
I do not know where the ORA-00923 error occurs, because the view compiles
without problems, as well as displays in mapguide 6.5 so the view seems to
be fine.
I am using Oracle 10g R2 and Mapguide Opensource 2.0.2 on windows server
2003, with KingOra v0_8_5.
Does anyone have an idea as to where this error comes from?
Kind Regards,
Marius
View this message in context: http://n2.nabble.com/Ora-error-when-displaying-layer-from-view-tp2334574p2334574.html
