[mapguide-users] Regarding How to set the Initial Map View
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Feb 17 03:08:06 EST 2009
There was a bug in Maestro that swapped some x/y coordinates, try using
the newest build (r3260).
Regards, Kenneth Skovhede, GEOGRAF A/S
ravinder.singh at BIRLASOFT.COM skrev:
> Hi All,
> How to set the Initial Map View (Lower Left and Upper Right (XY
> Coordinates)) in MapGuide Maestro.
> If I click on Set View to Current Layers Extent (In Maestro) & Run the
> layout then map does not appears in the viewer , seems that  map is
> there on the viewer but at different position which is not visible at
> startup, Because when I try to pan the map multiple times left or
> right up or down  it appears.
> I am using MGOS 2.0, .Net
> Please assist...
> *Thanks,*
> Ravi
> "This message and any attachments are solely for the intended
> recipient and may contain Birlasoft confidential or privileged
> information. If you are not the intended recipient,any
> disclosure,copying, use, or distribution of the information included
> in this message and any attachments is
> prohibited. If you have received this communication in error, please
> notify us by reply e-mail at (administrator at birlasoft.com) and
> permanently delete this message and any attachments. Thank you."
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090217/142e2b7b/attachment.html
