[mapguide-users] Problems with ODBC to .csv
Jackie Ng
jumpinjackie at gmail.com
Tue Feb 17 05:12:21 EST 2009
What are your feature source connection settings?
- Jackie
Micho Gar wrote:
> HiHi everybody,
> I am trying to connect Mapguide Server to a file through ODBC and I get
> the
> following error:
> Error en el servidor remoto: (559) MgFdoException.:
> An exception occurred in FDO component.
> RDBMS: No current open database.
> Exception occurred in method MgFdoConnectionManager.Open at line 858 in
> file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> Thanks.
> # michogar
> # Analista Programador SIG
> # Ubuntu Linux Counter 462666
> "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
> revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
> peor... Si lo reproduces del derecho... ¡Se instala!."
> "It has a legend that if you play an original Windows Vista DVD backwards
> to
> hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
> you play it right ... It installs!.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Problems-with-ODBC-to-.csv-tp2339887p2340013.html
