[mapguide-users] Problems with ODBC to .csv
Micho Gar michogar at gmail.com
Tue Feb 17 05:28:16 EST 2009
Hi Jackie, this is my connection
Driver={Microsoft Text Driver (*.txt;
*.csv)};Dbq=%MG_DATA_FILE_PATH%puntosGPS.csv;Extensions=asc,csv,tab,txt;Uid=;Pwd=
Thanks.
2009/2/17 Jackie Ng <jumpinjackie at gmail.com>
> What are your feature source connection settings?
> - Jackie
> Micho Gar wrote:
> > HiHi everybody,
> > I am trying to connect Mapguide Server to a file through ODBC and I get
> > the
> > following error:
> > Error en el servidor remoto: (559) MgFdoException.:
> > An exception occurred in FDO component.
> > RDBMS: No current open database.
> > Exception occurred in method MgFdoConnectionManager.Open at line 858 in
> > file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> > Thanks.
> > # michogar
> > # Analista Programador SIG
> > # Ubuntu Linux Counter 462666
> > "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
> > revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
> > peor... Si lo reproduces del derecho... ¡Se instala!."
> > "It has a legend that if you play an original Windows Vista DVD backwards
> > to
> > hear Bill Gates Satanic chanting songs ... But that's not the worst ...
> If
> > you play it right ... It installs!.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Problems-with-ODBC-to-.csv-tp2339887p2340013.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
# michogar
"It has a legend that if you play an original Windows Vista DVD backwards to
hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090217/c4e80bc9/attachment.html
