[mapguide-users] Fusion 2.0 Beta Notes
Berdel, Brian
brian.berdel at mcmtrans.com
Tue Feb 17 15:05:21 EST 2009
Hi guys, some of these improvements are great and this version will def be the best yet once.
I tested in the bundled standard template and I am seeing the same issues as mark described
Everything is in meters including the measure tool. No Tool-Tips, etc
Also, Tiled maps only work If I load them from the Map Menu...loading a tiled map as my initial map creates the legend but the map is empty when setting Single Tile = false. However if I load it from the map menu it shows up correctly
Thanks,
Brian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark Pendergraft
Sent: Tuesday, February 17, 2009 12:13 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Fusion 2.0 Beta Notes
Paul,
I have been experimenting with both the MapGuide standard template and
my own.
Apparently I had a coordinate system issue in my map that I was testing
(changed it and forgot to change it back), which explains the negative X
value. Although my map is still reporting in meters despite being in
feet.
Still at a loss as to the other issues though.
-Mark
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer
Sent: Tuesday, February 17, 2009 4:53 AM
Subject: Re: [mapguide-users] Fusion 2.0 Beta Notes
Thanks for the feedback Mark, we'll try to take a look at these
issues. Which template are you using, or is it one that you have
created?
Paul
On 16-Feb-09, at 9:17 PM, Mark Pendergraft wrote:
> I'm trying to implement Google Maps into my Fusion application using
> the 2.0 Beta. I'm having a bit of trouble. Right now I'm trying to
> load the Sheboygan map and the google map in the same MapGroup and
> my program has continuous errors (which seem to point to the
> maptip). I also have to disable the OverviewMap when I load the
> google map because it crashes when it loads.
> Can anyone provide some instructions or a brief overview on how we
> should be incorporating MapGuide and Google Maps into the same map?
> Also, I've noticed a few other bugs in 2.0:
> The CursorPosition widget does not show up in default layout unless
> the widget is added twice to the Statusbar container. It would
> appear that the second element in the statusbar container is
> actually overlapping the first element. So the element is there,
> but you can't see it because the second element in the container is
> on top of it. This happens with all Splitterbar controls added to
> the layout.
> Neither Tooltips nor the MapTip appear to work.
> The Coordinates in the CursorPosition widget appear to be
> incorrect. The X value is always negative (on the Sheboygan example
> and on my own map which is in Washington State Plane Coordinate
> System (HPGN) North Zone US Foot). A negative X value in a
> Washington state projection would indicate a position somewhere in
> the ocean.
> Another issue I've noticed with the CursorPosition widget is that it
> always seems to report in meters despite my map being in Feet. The
> widget reports in my maps units (feet), but appends a 'm' on the end
> of the X and Y.
> Thanks
> -Mark P.s
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
