[mapguide-users] Create programmatically a map
sekko970
sekko970 at virgilio.it
Wed Feb 18 03:57:16 EST 2009
Hi Kenneth,
I need again your help about my problem.
I think the problem is that after new map run-time creation in library
repository, I cannot use its map definition to create its web layout.
How can I assign the new map to the layout?
Thanks again, Fabio
Kenneth Skovhede, GEOGRAF A/S wrote:
> Try to look at the Maestro code:
> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/LocalNativeConnection.cs#L182
> Hopefully you will find a small difference there.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> sekko970 skrev:
>> Yes, the "OuterXml" property contains the XML header line.
>> Fabio
>>> Does the "OuterXml" property contain the <? version="1.0"
>>> encoding="utf-8" standalone="true" ?> line?
>>> sekko970 skrev:
>>>> Hi Kenneth, and thanks for your promptly reply.
>>>> I had used an ancoding instance.
>>>> Below, you can see my code to create the new map:
>>>> Dim resID As New
>>>> MgResourceIdentifier(Library://.../maps/MyMap.MapDefinition)
>>>> Dim enc As New System.Text.UTF8Encoding(False)
>>>> Dim newMapDef As New
>>>> MgByteSource(enc.GetBytes(XMLMapTemplate.OuterXml),
>>>> enc.GetByteCount(XMLMapTemplate.OuterXml))
>>>> newMapDef.SetMimeType(MgMimeType.Xml)
>>>> Dim resourceSrvc As MgResourceService =
>>>> siteConn.CreateService(MgServiceType.ResourceService)
>>>> resourceSrvc.SetResource(resID, newMapDef.GetReader(), Nothing)
>>>> Dim map As New MgMap()
>>>> map.Create(resourceSrvc, resID, MapName)
>>>> Then, this is my code to create the map layout:
>>>> Dim resID As New
>>>> MgResourceIdentifier(Library://.../Layouts/MyMap.WebLayout)
>>>> Dim newLayoutDef As New
>>>> MgByteSource(enc.GetBytes(XMLLayoutTemplate.OuterXml),
>>>> enc.GetByteCount(XMLLayoutTemplate.OuterXml))
>>>> newLayoutDef.SetMimeType(MgMimeType.Xml)
>>>> resourceSrvc.SetResource(resID, newLayoutDef.GetReader(), Nothing)
>>>> map.Save(resourceSrvc)
>>>> Thanks for your help.
>>>> Fabio
>>>>> You could have the problem that .Net emits an utf-8 byte-order-marker
>>>>> (BOM), when
>>>>> writing xml.
>>>>> http://en.wikipedia.org/wiki/Byte-order_mark
>>>>> To counter this, explicitly create an encoding instance:
>>>>> System.Text.Encoding enc = new System.Text.UTF8Encoding(false);
>>>>> Then implement a xml writer, or manually convert the xml to bytes,
>>>>> using
>>>>> the encoding.
>>>>> FYI, the MaestroAPI is LGPL, and so you may use it as a library, even
>>>>> for commercial applications,
>>>>> and it handles this quirk and others.
>>>>> sekko970 skrev:
>>>>>> Dear all,
>>>>>> I have created programmatically a map (and its layout) using MG .Net
>>>>>> web
>>>>>> API.
>>>>>> After creation, the new map and layout are visible in MG Maestro, and
>>>>>> using
>>>>>> the 'Show in browser" button are correctly shown in browser.
>>>>>> The problem happens when I load the map directly from browser, and
>>>>>> the
>>>>>> following error appears:
>>>>>> << The type 'OSGeo.MapGuide.MgNullArgumentException' in assembly
>>>>>> 'MapGuideDotNetApi, Version= 2.0.2.30 11, Culture=neutral,
>>>>>> PublicKeyToken=null' is not marked as serializable >>.
>>>>>> Then, simply saving the new layout from MG Maestro (without any
>>>>>> modification), and reloading the map directly from browser, the error
>>>>>> disappears and the map is correctly shown.
>>>>>> After saving the layout, there aren't differences in map and layout
>>>>>> XML
>>>>>> definitions.
>>>>>> Have you any idea about?
>>>>>> Thank you in advance.
>>>>>> Fabio
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345737.html
