[mapguide-users] Problems with ODBC to .csv
Micho Gar
michogar at gmail.com
Wed Feb 18 05:50:59 EST 2009
Hi, I managed to connect through ODBC, but I do not see the items on the
map, to create the layer said: An exception occurred in FDO component. Table
does not exist for class' Default: puntosGPS_csv ', you know that you can
be?
Thank you all.
2009/2/17 Dave Wilson <dave.wilson at autodesk.com>
> I think you will find that the ODBC provider doesn't work with Text files
> in MGE. I'm pretty sure there's a bug.
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Micho Gar
> *Sent:* Tuesday, February 17, 2009 3:28 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Problems with ODBC to .csv
> Hi Jackie, this is my connection
> Driver={Microsoft Text Driver (*.txt;
> *.csv)};Dbq=%MG_DATA_FILE_PATH%puntosGPS.csv;Extensions=asc,csv,tab,txt;Uid=;Pwd=
> Thanks.
> 2009/2/17 Jackie Ng <jumpinjackie at gmail.com>
> What are your feature source connection settings?
> - Jackie
> Micho Gar wrote:
> > HiHi everybody,
> > I am trying to connect Mapguide Server to a file through ODBC and I get
> > the
> > following error:
> > Error en el servidor remoto: (559) MgFdoException.:
> > RDBMS: No current open database.
> > Exception occurred in method MgFdoConnectionManager.Open at line 858 in
> > file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> > Thanks.
> > # michogar
> > # Analista Programador SIG
> > # Ubuntu Linux Counter 462666
> > "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
> > revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
> > peor... Si lo reproduces del derecho... ¡Se instala!."
> > "It has a legend that if you play an original Windows Vista DVD backwards
> > to
> > hear Bill Gates Satanic chanting songs ... But that's not the worst ...
> If
> > you play it right ... It installs!.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Problems-with-ODBC-to-.csv-tp2339887p2340013.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> # michogar
> to hear Bill Gates Satanic chanting songs ... But that's not the worst ...
> If you play it right ... It installs!.
# michogar
"It has a legend that if you play an original Windows Vista DVD backwards to
hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090218/1511e2e6/attachment.html
