[mapguide-users] Problems with ODBC to .csv
Dave Wilson
dave.wilson at autodesk.com
Wed Feb 18 11:38:14 EST 2009
That is the bug.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Micho Gar
Sent: Wednesday, February 18, 2009 3:51 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Problems with ODBC to .csv
Hi, I managed to connect through ODBC, but I do not see the items on the map, to create the layer said: An exception occurred in FDO component. Table does not exist for class' Default: puntosGPS_csv ', you know that you can be?
Thank you all.
2009/2/17 Dave Wilson <dave.wilson at autodesk.com<mailto:dave.wilson at autodesk.com>>
I think you will find that the ODBC provider doesn't work with Text files in MGE. I'm pretty sure there's a bug.
Dave
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>] On Behalf Of Micho Gar
Sent: Tuesday, February 17, 2009 3:28 AM
Hi Jackie, this is my connection
Driver={Microsoft Text Driver (*.txt; *.csv)};Dbq=%MG_DATA_FILE_PATH%puntosGPS.csv;Extensions=asc,csv,tab,txt;Uid=;Pwd=
Thanks.
2009/2/17 Jackie Ng <jumpinjackie at gmail.com<mailto:jumpinjackie at gmail.com>>
What are your feature source connection settings?
- Jackie
Micho Gar wrote:
> HiHi everybody,
> I am trying to connect Mapguide Server to a file through ODBC and I get
> the
> following error:
> Error en el servidor remoto: (559) MgFdoException.:
> RDBMS: No current open database.
> Exception occurred in method MgFdoConnectionManager.Open at line 858 in
> file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> Thanks.
> # michogar
> # Analista Programador SIG
> # Ubuntu Linux Counter 462666
> "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
> revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
> peor... Si lo reproduces del derecho... ¡Se instala!."
> "It has a legend that if you play an original Windows Vista DVD backwards
> to
> hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
> you play it right ... It installs!.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
View this message in context: http://n2.nabble.com/Problems-with-ODBC-to-.csv-tp2339887p2340013.html
# michogar
"Cuenta una leyenda que si reproduces un DVD de Windows Vista original al revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo peor... Si lo reproduces del derecho... ¡Se instala!."
"It has a legend that if you play an original Windows Vista DVD backwards to hear Bill Gates Satanic chanting songs ... But that's not the worst ... If you play it right ... It installs!.
# michogar
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090218/af3eb776/attachment.html
