[mapguide-users] Create programmatically a map
Ivan Milicevic Ivan.Milicevic at supranet.hr
Wed Feb 18 09:52:18 EST 2009
Hm... Try pass byteReader object instead of newLayoutDef.GetReader().
PHP SAMPLE:
// Get a resource identifier for the library
 $resourceID = new MgResourceIdentifier('Library://');
 // Read the new content from a file
 $byteSource = new MgByteSource('C:\Data\Repository\Content.xml');
 // Put that MgByteSource into an MgByteReader
 $byteReader = $byteSource->GetReader();
 // Update the repository content
 $resourceService->UpdateRepository($resourceID, $byteReader, null);
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sekko970
Sent: Wednesday, February 18, 2009 3:28 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Create programmatically a map
I'm sorry Ivan, is a copy/paste error!
Ivan Milicevic wrote:
> Is it double "r" in resID copy/paste error?
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Wednesday, February 18, 2009 3:20 PM
> Each try is failed for the following error: 'Invalid resource type'.
> Dim resID As New MgResourceIdentifier("Librarry://.../" & MyLayout &
> MgResourceType.WebLayout)
> Dim enc As New System.Text.UTF8Encoding(False)
> Dim newLayoutDef As New
> MgByteSource(enc.GetBytes(newLayoutXML.OuterXml),
> enc.GetByteCount(newLayoutXML.OuterXml))
> newLayoutDef.SetMimeType(MgMimeType.Xml)
> resourceSrvc.SetResource(resID, newLayoutDef.GetReader(), Nothing)
> map.Save(resourceSrvc)
> resourceSrvc.UpdateRepository(resID, newLayoutDef.GetReader(),
Nothing)
>> I'm guessing that you must update repository after creating new
> layout.
>> Look at
http://mapguide.osgeo.org/files/mapguide/docs/2.0/d8/de1/class_mg_resour
>> ce_service_e0294dc308ecc4708b79d493086f210b.htm
>> Sent: Wednesday, February 18, 2009 2:01 PM
>> Sure, this is the related record in error log:
>> <2009-02-18T12:07:11> 			Administrator
>>  Error: Resource was not found:
Session:36fb9200-0000-1000-8000-000bcd727323_en_7F0000010AFC0AFB0AFA//ne
>> w.Map
>>  StackTrace:
>>   - MgResourceServiceHandler.ProcessOperation line 80 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
>> \resource\ResourceServiceHandler.cpp
>>   - MgOpGetResourceData.Execute line 124 file
>> \resource\OpGetResourceData.cpp
>>   - MgServerResourceService.GetResourceData line 1401 file
>> \resource\ServerResourceService.cpp
>>   - MgApplicationRepositoryManager.GetResourceData line 1201 file
>> \resource\ApplicationRepositoryManager.cpp
>>   - MgResourceContentManager.GetDocument line 590 file
>> \resource\ResourceContentManager.cpp
>>   - MgResourceDefinitionManager.GetDocument line 476 file
>> \resource\ResourceDefinitionManager.cpp
>> w.Map
>>> Very interesting... Can you check mapguide error log? Is there any
>>> records related with this problem?
sekko970
>>> Sent: Wednesday, February 18, 2009 12:41 PM
>>> Below you can see the new map and layout XML created from
>>> http://localhost/mapguide/mapagent/index.html before and after the
>>> saving
>>> from Maestro (is equals for both).
>>>   <?xml version="1.0" encoding="UTF-8" ?>
>>> - <ResourceList
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xsi:noNamespaceSchemaLocation="ResourceList-1.0.0.xsd">
>>> - <ResourceDocument>
>>>   <ResourceId>Library://.../newMap.MapDefinition</ResourceId>
>>>   <Depth>3</Depth>
>>>   <Owner>Administrator</Owner>
>>>   <CreatedDate>2009-02-18T11:31:29Z</CreatedDate>
>>>   <ModifiedDate>2009-02-18T11:31:29Z</ModifiedDate>
>>> - <ResourceDocumentHeader
>>> xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
>>> - <Security
>> xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
>>>   <Inherited>true</Inherited>
>>> - <Groups>
>>> - <Group>
>>>   <Name>Everyone</Name>
>>>   <Permissions>r,w</Permissions>
>>>   </Group>
>>>   </Groups>
>>>   </Security>
>>>   </ResourceDocumentHeader>
>>>   </ResourceDocument>
>>>   </ResourceList>
>>> - <ResourceList
>>>   <ResourceId>Library://.../newLayout.WebLayout</ResourceId>
>>>   <Depth>3</Depth>
>>>   <CreatedDate>2009-02-18T11:35:51Z</CreatedDate>
>>>   <ModifiedDate>2009-02-18T11:36:32Z</ModifiedDate>
>>> - <Security
>>> - <Groups>
>>> - <Group>
>>>   </Group>
>>>   </Groups>
>>>   </Security>
>>>   </ResourceDocument>
>>>   </ResourceList>
>>>> Please, before you open layout and map in Maestro go to:
>>>> http://localhost/mapguide/mapagent/index.html -> go to
>>>> Resource-->GetResourceContent--> and type correct resource ID on
>> right
>>>> side. See is there any strange things in output XML file. Compare
it
>>>> after saving it in Maestro.
> sekko970
>>>> Sent: Wednesday, February 18, 2009 12:05 PM
>>>> This is my problem:
>>>> I have created programmatically a map (and its layout) using MG
.Net
>>> web
>>>> API.
>>>> After creation, the new map and layout are visible in MG Maestro,
> and
>>>> using
>>>> the 'Show in browser" button are correctly shown in browser.
>>>> The problem happens when I load the map directly from browser, and
>> the
>>>> following error appears:
>>>> << The type 'OSGeo.MapGuide.MgNullArgumentException' in assembly
>>>> 'MapGuideDotNetApi, Version= 2.0.2.30 11, Culture=neutral,
>>>> PublicKeyToken=null' is not marked as serializable >>.
>>>> Then, simply saving the new layout from MG Maestro (without any
>>>> modification), and reloading the map directly from browser, the
> error
>>>> disappears and the map is correctly shown.
>>>> After saving the layout, there aren't differences in map and layout
>>> XML
>>>> definitions.
>>>> Have you any idea about?
>>>>> Can you write pseudo code of your task? What do you want to do? I
>>> need
>>>>> little more information about your problem.
>> sekko970
>>>>> Sent: Wednesday, February 18, 2009 11:42 AM
>>>>> Hi Ivan,
>>>>> below, you can see my code to create the new map:
>>>>> Dim resID As New
>>>>> MgResourceIdentifier(Library://.../maps/MyMap.MapDefinition)
>>>>> Dim newMapDef As New
>>>> MgByteSource(enc.GetBytes(XMLMapTemplate.OuterXml),
>>>>> enc.GetByteCount(XMLMapTemplate.OuterXml))
>>>>> newMapDef.SetMimeType(MgMimeType.Xml)
>>>>> Dim resourceSrvc As MgResourceService =
>>>>> siteConn.CreateService(MgServiceType.ResourceService)
>>>>> resourceSrvc.SetResource(resID, newMapDef.GetReader(), Nothing)
>>>>> Dim map As New MgMap()
>>>>> map.Create(resourceSrvc, resID, MapName)
>>>>> Then, this is my code to create the map layout:
>>>>> Dim resID As New
>>>>> MgResourceIdentifier(Library://.../Layouts/MyMap.WebLayout)
>>>>> MgByteSource(enc.GetBytes(XMLLayoutTemplate.OuterXml),
>>>>> enc.GetByteCount(XMLLayoutTemplate.OuterXml))
>>>>> Perhaps between map and layout creation I should refresh the
>> mapframe
>>>> as
>>>>> suggested from you?
>>>>> Thanks in advance for your help.
>>>>> Fabio
>>>>>> Can you provide us code sample?
>>> sekko970
>>>>>> Sent: Wednesday, February 18, 2009 10:38 AM
>>>>>> Hi Ivan,
>>>>>> thanks for your suggestion, but my problem is not to refresh the
>>>>> viewer
>>>>>> to
>>>>>> show the map just created, but is the correct creation of new map
>>> and
>>>>>> layout.
>>>>>> I think to have found the origin of my problem, but I don't
>>>> understand
>>>>>> the
>>>>>> error:
>>>>>> Argument is null. Exception occurred in method
>>>>>> MgWebLayout.ParsePrintCommand
>>>>>> at line 880 in file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\web\src\webapp\WebLayo
>>>>>> ut.cpp
>>>>>> Have you some idea?
>>>>>> Thanks, Fabio
>>>>>>> Hello,
>>>>>>> You can change href of mapFrame. Here is sample code.
>>>>>>> var mapa = "cijevi"; //defines map name
>>>>>>> var stringMape = "Library%3a%2f%2fPROJEKTI%2fSUPRANET%2fMAPE%2f"
>>>>>> mapa;
>>>>>>> var hrefMapa =
"http://172.21.10.3/mapguide/mapviewernet/mapframe.aspx?MAPDEFINITION="
>>>>>>> + stringMape +
".MapDefinition&amp;TYPE=HTML&amp;SHOWLEGEND=0&amp;SHOWPROP=0&amp;INFOWI
DTH=0&amp;LOCALE=en&amp;HLTGT=1&amp;HLTGTNAME=&amp;SHOWSLIDER=0&amp;SESS
>>>>>>> ION=" + mgSessionId + ";
>>>>>>> //changing mapFrame href
>>>>>>> mapFrame.location.href = hrefMapa;
>>>>>>> Hope this helps.
>>>> sekko970
>>>>>>> Sent: Wednesday, February 18, 2009 9:57 AM
>>>>>>> Subject: Re: [mapguide-users] Create programmatically a map
>>>>>>> Hi Kenneth,
>>>>>>> I need again your help about my problem.
>>>>>>> I think the problem is that after new map run-time creation in
>>>>> library
>>>>>>> repository, I cannot use its map definition to create its web
>>>> layout.
>>>>>>> How can I assign the new map to the layout?
>>>>>>> Thanks again, Fabio
>>>>>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>>>>>> Try to look at the Maestro code:
http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Lo
>>>>>>> calNativeConnection.cs#L182
>>>>>>>> Hopefully you will find a small difference there.
>>>>>>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>>>>>>> sekko970 skrev:
>>>>>>>>> Yes, the "OuterXml" property contains the XML header line.
>>>>>>>>> Fabio
>>>>>>>>>> Does the "OuterXml" property contain the <? version="1.0"
>>>>>>>>>> encoding="utf-8" standalone="true" ?> line?
>>>>>>>>>> sekko970 skrev:
>>>>>>>>>>> Hi Kenneth, and thanks for your promptly reply.
>>>>>>>>>>> I had used an ancoding instance.
>>>>>>>>>>> Below, you can see my code to create the new map:
>>>>>>>>>>> Dim resID As New
>> Nothing)
>>>>>>>>>>> Dim resID As New
>>>>> Nothing)
>>>>>>>>>>> Thanks for your help.
>>>>>>>>>>> Fabio
>>>>>>>>>>>> You could have the problem that .Net emits an utf-8
>>>>>>> byte-order-marker
>>>>>>>>>>>> (BOM), when
>>>>>>>>>>>> writing xml.
>>>>>>>>>>>> http://en.wikipedia.org/wiki/Byte-order_mark
>>>>>>>>>>>> To counter this, explicitly create an encoding instance:
>>>>>>>>>>>> System.Text.Encoding enc = new
>>> System.Text.UTF8Encoding(false);
>>>>>>>>>>>> Then implement a xml writer, or manually convert the xml to
>>>>>> bytes,
>>>>>>>>>>>> using
>>>>>>>>>>>> the encoding.
>>>>>>>>>>>> FYI, the MaestroAPI is LGPL, and so you may use it as a
>>>> library,
>>>>>>> even
>>>>>>>>>>>> for commercial applications,
>>>>>>>>>>>> and it handles this quirk and others.
>>>>>>>>>>>> sekko970 skrev:
>>>>>>>>>>>>> Dear all,
> using
>>>> MG
>>>>>>> .Net
>>>>>>>>>>>>> web
>>>>>>>>>>>>> API.
>>>>>> Maestro,
>>>>>>> and
>>>>>>>>>>>>> using
> browser.
>>> browser,
>>>>>>> and
>>>>>>>>>>>>> the
>>>>> assembly
(without
>>>> any
browser,
>>>> the
>>>>>>> error
> and
>>>>>>> layout
>>>>>>>>>>>>> XML
>>>>>>>>>>>>> definitions.
>>>>>>>>>>>>> Thank you in advance.
>>>>>>>>>>>>> Fabio
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>> View this message in context:
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345737.htm
>>>>>>> l
>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345874.htm
>>>>>> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346122.htm
>>>>> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346216.htm
>>>> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346367.htm
>>> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346704.htm
>> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2347057.htm
> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2347096.htm
l
