[mapguide-users] Create programmatically a map
sekko970
sekko970 at virgilio.it
Wed Feb 18 11:31:52 EST 2009
Tryed, but no changes.
Ivan Milicevic wrote:
> Hm... Try pass byteReader object instead of newLayoutDef.GetReader().
> PHP SAMPLE:
> // Get a resource identifier for the library
> $resourceID = new MgResourceIdentifier('Library://');
> // Read the new content from a file
> $byteSource = new MgByteSource('C:\Data\Repository\Content.xml');
> // Put that MgByteSource into an MgByteReader
> $byteReader = $byteSource->GetReader();
> // Update the repository content
> $resourceService->UpdateRepository($resourceID, $byteReader, null);
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sekko970
> Sent: Wednesday, February 18, 2009 3:28 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Create programmatically a map
> I'm sorry Ivan, is a copy/paste error!
>> Is it double "r" in resID copy/paste error?
>> Sent: Wednesday, February 18, 2009 3:20 PM
>> Each try is failed for the following error: 'Invalid resource type'.
>> Dim resID As New MgResourceIdentifier("Librarry://.../" & MyLayout &
>> MgResourceType.WebLayout)
>> Dim enc As New System.Text.UTF8Encoding(False)
>> Dim newLayoutDef As New
>> MgByteSource(enc.GetBytes(newLayoutXML.OuterXml),
>> enc.GetByteCount(newLayoutXML.OuterXml))
>> newLayoutDef.SetMimeType(MgMimeType.Xml)
>> resourceSrvc.SetResource(resID, newLayoutDef.GetReader(), Nothing)
>> map.Save(resourceSrvc)
>> resourceSrvc.UpdateRepository(resID, newLayoutDef.GetReader(),
> Nothing)
>>> I'm guessing that you must update repository after creating new
>> layout.
>>> Look at
> http://mapguide.osgeo.org/files/mapguide/docs/2.0/d8/de1/class_mg_resour
>>> ce_service_e0294dc308ecc4708b79d493086f210b.htm
>>> Sent: Wednesday, February 18, 2009 2:01 PM
>>> Sure, this is the related record in error log:
>>> <2009-02-18T12:07:11> Administrator
>>> Error: Resource was not found:
> Session:36fb9200-0000-1000-8000-000bcd727323_en_7F0000010AFC0AFB0AFA//ne
>>> w.Map
>>> StackTrace:
>>> - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
>>> \resource\ResourceServiceHandler.cpp
>>> - MgOpGetResourceData.Execute line 124 file
>>> \resource\OpGetResourceData.cpp
>>> - MgServerResourceService.GetResourceData line 1401 file
>>> \resource\ServerResourceService.cpp
>>> - MgApplicationRepositoryManager.GetResourceData line 1201 file
>>> \resource\ApplicationRepositoryManager.cpp
>>> - MgResourceContentManager.GetDocument line 590 file
>>> \resource\ResourceContentManager.cpp
>>> - MgResourceDefinitionManager.GetDocument line 476 file
>>> \resource\ResourceDefinitionManager.cpp
>>> w.Map
>>>> Very interesting... Can you check mapguide error log? Is there any
>>>> records related with this problem?
> sekko970
>>>> Sent: Wednesday, February 18, 2009 12:41 PM
>>>> Below you can see the new map and layout XML created from
>>>> http://localhost/mapguide/mapagent/index.html before and after the
>>>> saving
>>>> from Maestro (is equals for both).
>>>> <?xml version="1.0" encoding="UTF-8" ?>
>>>> - <ResourceList
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>> xsi:noNamespaceSchemaLocation="ResourceList-1.0.0.xsd">
>>>> - <ResourceDocument>
>>>> <ResourceId>Library://.../newMap.MapDefinition</ResourceId>
>>>> <Depth>3</Depth>
>>>> <Owner>Administrator</Owner>
>>>> <CreatedDate>2009-02-18T11:31:29Z</CreatedDate>
>>>> <ModifiedDate>2009-02-18T11:31:29Z</ModifiedDate>
>>>> - <ResourceDocumentHeader
>>>> xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
>>>> - <Security
>>> xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
>>>> <Inherited>true</Inherited>
>>>> - <Groups>
>>>> - <Group>
>>>> <Name>Everyone</Name>
>>>> <Permissions>r,w</Permissions>
>>>> </Group>
>>>> </Groups>
>>>> </Security>
>>>> </ResourceDocumentHeader>
>>>> </ResourceDocument>
>>>> </ResourceList>
>>>> - <ResourceList
>>>> <ResourceId>Library://.../newLayout.WebLayout</ResourceId>
>>>> <Depth>3</Depth>
>>>> <CreatedDate>2009-02-18T11:35:51Z</CreatedDate>
>>>> <ModifiedDate>2009-02-18T11:36:32Z</ModifiedDate>
>>>> - <Security
>>>> - <Groups>
>>>> - <Group>
>>>> </Group>
>>>> </Groups>
>>>> </Security>
>>>> </ResourceDocument>
>>>> </ResourceList>
>>>>> Please, before you open layout and map in Maestro go to:
>>>>> http://localhost/mapguide/mapagent/index.html -> go to
>>>>> Resource-->GetResourceContent--> and type correct resource ID on
>>> right
>>>>> side. See is there any strange things in output XML file. Compare
> it
>>>>> after saving it in Maestro.
>> sekko970
>>>>> Sent: Wednesday, February 18, 2009 12:05 PM
>>>>> This is my problem:
>>>>> I have created programmatically a map (and its layout) using MG
> .Net
>>>> web
>>>>> API.
>>>>> After creation, the new map and layout are visible in MG Maestro,
>> and
>>>>> using
>>>>> the 'Show in browser" button are correctly shown in browser.
>>>>> The problem happens when I load the map directly from browser, and
>>> the
>>>>> following error appears:
>>>>> << The type 'OSGeo.MapGuide.MgNullArgumentException' in assembly
>>>>> 'MapGuideDotNetApi, Version= 2.0.2.30 11, Culture=neutral,
>>>>> PublicKeyToken=null' is not marked as serializable >>.
>>>>> Then, simply saving the new layout from MG Maestro (without any
>>>>> modification), and reloading the map directly from browser, the
>> error
>>>>> disappears and the map is correctly shown.
>>>>> After saving the layout, there aren't differences in map and layout
>>>> XML
>>>>> definitions.
>>>>> Have you any idea about?
>>>>>> Can you write pseudo code of your task? What do you want to do? I
>>>> need
>>>>>> little more information about your problem.
>>> sekko970
>>>>>> Sent: Wednesday, February 18, 2009 11:42 AM
>>>>>> Hi Ivan,
>>>>>> below, you can see my code to create the new map:
>>>>>> Dim resID As New
>>>>>> MgResourceIdentifier(Library://.../maps/MyMap.MapDefinition)
>>>>>> Dim newMapDef As New
>>>>> MgByteSource(enc.GetBytes(XMLMapTemplate.OuterXml),
>>>>>> enc.GetByteCount(XMLMapTemplate.OuterXml))
>>>>>> newMapDef.SetMimeType(MgMimeType.Xml)
>>>>>> Dim resourceSrvc As MgResourceService =
>>>>>> siteConn.CreateService(MgServiceType.ResourceService)
>>>>>> resourceSrvc.SetResource(resID, newMapDef.GetReader(), Nothing)
>>>>>> Dim map As New MgMap()
>>>>>> map.Create(resourceSrvc, resID, MapName)
>>>>>> Then, this is my code to create the map layout:
>>>>>> Dim resID As New
>>>>>> MgResourceIdentifier(Library://.../Layouts/MyMap.WebLayout)
>>>>>> MgByteSource(enc.GetBytes(XMLLayoutTemplate.OuterXml),
>>>>>> enc.GetByteCount(XMLLayoutTemplate.OuterXml))
>>>>>> Perhaps between map and layout creation I should refresh the
>>> mapframe
>>>>> as
>>>>>> suggested from you?
>>>>>> Thanks in advance for your help.
>>>>>> Fabio
>>>>>>> Can you provide us code sample?
>>>> sekko970
>>>>>>> Sent: Wednesday, February 18, 2009 10:38 AM
>>>>>>> Hi Ivan,
>>>>>>> thanks for your suggestion, but my problem is not to refresh the
>>>>>> viewer
>>>>>>> to
>>>>>>> show the map just created, but is the correct creation of new map
>>>> and
>>>>>>> layout.
>>>>>>> I think to have found the origin of my problem, but I don't
>>>>> understand
>>>>>>> the
>>>>>>> error:
>>>>>>> Argument is null. Exception occurred in method
>>>>>>> MgWebLayout.ParsePrintCommand
>>>>>>> at line 880 in file
> c:\build_bond_area\bond_nightly\build_41.3\ent\os\web\src\webapp\WebLayo
>>>>>>> ut.cpp
>>>>>>> Have you some idea?
>>>>>>> Thanks, Fabio
>>>>>>>> Hello,
>>>>>>>> You can change href of mapFrame. Here is sample code.
>>>>>>>> var mapa = "cijevi"; //defines map name
>>>>>>>> var stringMape = "Library%3a%2f%2fPROJEKTI%2fSUPRANET%2fMAPE%2f"
>>>>>>> mapa;
>>>>>>>> var hrefMapa =
> "http://172.21.10.3/mapguide/mapviewernet/mapframe.aspx?MAPDEFINITION="
>>>>>>>> + stringMape +
> ".MapDefinition&TYPE=HTML&SHOWLEGEND=0&SHOWPROP=0&INFOWI
> DTH=0&LOCALE=en&HLTGT=1&HLTGTNAME=&SHOWSLIDER=0&SESS
>>>>>>>> ION=" + mgSessionId + ";
>>>>>>>> //changing mapFrame href
>>>>>>>> mapFrame.location.href = hrefMapa;
>>>>>>>> Hope this helps.
>>>>> sekko970
>>>>>>>> Sent: Wednesday, February 18, 2009 9:57 AM
>>>>>>>> Subject: Re: [mapguide-users] Create programmatically a map
>>>>>>>> Hi Kenneth,
>>>>>>>> I need again your help about my problem.
>>>>>>>> I think the problem is that after new map run-time creation in
>>>>>> library
>>>>>>>> repository, I cannot use its map definition to create its web
>>>>> layout.
>>>>>>>> How can I assign the new map to the layout?
>>>>>>>> Thanks again, Fabio
>>>>>>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>>>>>>> Try to look at the Maestro code:
> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Lo
>>>>>>>> calNativeConnection.cs#L182
>>>>>>>>> Hopefully you will find a small difference there.
>>>>>>>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>>>>>>>> sekko970 skrev:
>>>>>>>>>> Yes, the "OuterXml" property contains the XML header line.
>>>>>>>>>> Fabio
>>>>>>>>>>> Does the "OuterXml" property contain the <? version="1.0"
>>>>>>>>>>> encoding="utf-8" standalone="true" ?> line?
>>>>>>>>>>> sekko970 skrev:
>>>>>>>>>>>> Hi Kenneth, and thanks for your promptly reply.
>>>>>>>>>>>> I had used an ancoding instance.
>>>>>>>>>>>> Below, you can see my code to create the new map:
>>>>>>>>>>>> Dim resID As New
>>> Nothing)
>>>>>>>>>>>> Dim resID As New
>>>>>> Nothing)
>>>>>>>>>>>> Thanks for your help.
>>>>>>>>>>>> Fabio
>>>>>>>>>>>>> You could have the problem that .Net emits an utf-8
>>>>>>>> byte-order-marker
>>>>>>>>>>>>> (BOM), when
>>>>>>>>>>>>> writing xml.
>>>>>>>>>>>>> http://en.wikipedia.org/wiki/Byte-order_mark
>>>>>>>>>>>>> To counter this, explicitly create an encoding instance:
>>>>>>>>>>>>> System.Text.Encoding enc = new
>>>> System.Text.UTF8Encoding(false);
>>>>>>>>>>>>> Then implement a xml writer, or manually convert the xml to
>>>>>>> bytes,
>>>>>>>>>>>>> using
>>>>>>>>>>>>> the encoding.
>>>>>>>>>>>>> FYI, the MaestroAPI is LGPL, and so you may use it as a
>>>>> library,
>>>>>>>> even
>>>>>>>>>>>>> for commercial applications,
>>>>>>>>>>>>> and it handles this quirk and others.
>>>>>>>>>>>>> sekko970 skrev:
>>>>>>>>>>>>>> Dear all,
>> using
>>>>> MG
>>>>>>>> .Net
>>>>>>>>>>>>>> web
>>>>>>>>>>>>>> API.
>>>>>>> Maestro,
>>>>>>>> and
>>>>>>>>>>>>>> using
>> browser.
>>>> browser,
>>>>>>>> and
>>>>>>>>>>>>>> the
>>>>>> assembly
> (without
>>>>> any
> browser,
>>>>> the
>>>>>>>> error
>> and
>>>>>>>> layout
>>>>>>>>>>>>>> XML
>>>>>>>>>>>>>> definitions.
>>>>>>>>>>>>>> Thank you in advance.
>>>>>>>>>>>>>> Fabio
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>>> View this message in context:
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345737.htm
>>>>>>>> l
>>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345874.htm
>>>>>>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346122.htm
>>>>>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346216.htm
>>>>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346367.htm
>>>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346704.htm
>>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2347057.htm
>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2347096.htm
> l
View this message in context: http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2347919.html
