[mapguide-users] ASP.NET MG2.0.2 - SelectFeatures Filter
Jackie Ng jumpinjackie at gmail.com
Thu Feb 19 00:03:00 EST 2009
What if you try single-quoting the numeric values?
- Jackie
Matteo wrote:
> Hi,
>   I have a point layer with filter that i set from MapGuide Studio 2009
> (the filter is "( Codec ='HR') AND  direction  = 'B->A' and  LQ  <= 2.50
> and MNC=10 and  valid =01 and  ValidTestInfo =01")
> Now I must select some whit this filter "( Codec ='HR') AND  direction  =
> 'B->A' and  LQ  <= 2.50 and MNC=10 and  valid =01 and  ValidTestInfo =01
> and ID_TESTTOW=262" but when I call the function SelectFeatures MapGuide
> give me the error "An exception occurred in FDO component.String does not
> represent a valid filter. "
> I try to use Server.HtmlEncode function to encode filter but I have the
> same error.
> Can you help me?
> Thanks
> Matteo
View this message in context: http://n2.nabble.com/ASP.NET-MG2.0.2---SelectFeatures-Filter-tp2346772p2351274.html
