[mapguide-users] Integration with Google Maps
Stefan Dalakov s.dalakov at mapware.net
Thu Feb 19 02:43:11 EST 2009
If you are serving it with MGOS, and if the problem is bandwidth or
loading time you can switch to kmz format, as Jackie says. If you have
it already produced, then you can save as kmz within GE, but I guess the
problem will be the complexity - GE has difficulty handling big files,
at least on my machine, so try optimizing the source data. MGOS serves
not the whole file but a viewport so you will not have this problem if
you use MGOS.
I have not ran into a function of software I use, which allows
processing(simplifying) of an already created  KML.
Stefan Dalakov
Jackie Ng wrote:
> MapGuide can serve compressed kml (kmz), which is many orders of magnitude
> smaller in size.
> - Jackie
> Sergio Nistal Calvo wrote:
>> Hi,
>> I have a kml file format, but its size is greater than 10 MB. How can I
>> reduce its size or simplify in order to upload to Google Maps? I've seen
>> online a post that says you can simplify it with Manifold GIS, but the
>> program is not free.
>> Thanks.
>> _________________________________________________________________
>> ¿Eres un cotilla? Disfruta de todas las novedades en MSN Corazón
>> http://entretenimiento.es.msn.com/corazon/
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
