[mapguide-users] Properties Value
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Thu Feb 19 06:10:51 EST 2009
Eh, It's look like that we found bug in FDO tools :(
Try with this one: http://www.sl-king.com/Fdo2Fdo/download/download.html
You cold create empty SDF file and define schema with new parameters the
execute copying from one SDF to another. That worked for me (converting
int to string).
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of staniz
Sent: Thursday, February 19, 2009 12:04 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Properties Value
Ivan, thank for your time and effort trying to solve my problem.
So far I couldn't change the property type. I follow your instructions
and
also give full access to the sdf file, and copy the internal Sdf file to
another folder, but still I couldn't change from decimal to Int32.
The following error come when I apply change to the schema.
The screennshot error :
http://n2.nabble.com/file/n2352387/error1.jpg
Ivan Milicevic wrote:
> Staniz,
> Here is instructions:
> 1. Go to http://code.google.com/p/fdotoolbox/downloads/list and
download
> last version of thisexcellent piece of software made by Jackie.
> 2. run it and in project explorer: new->connect to sdf
> 3. Pick your file
> 4. The connectionshould be added in object explorer
> 5. Right clockon it and chose "edit schema"
> 6. Pick your population class and on right side of program (schema
> designer) change datatype of class
> Here is screenshot.
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Thursday, February 19, 2009 6:50 AM
> Subject: Re: [mapguide-users] Properties Value
> it's ok, I will wait for the solution.
> staniz wrote:
>> I am using MGE and MG Studio 2008 and have layer and sdf file as
> polygon
>> feature type. In my table there is one field, a Property Name =
>> "Population" and Property Type = "double", I checked/selected this
>> property in "Properties displayed in the viewer" check box. when I
> select
>> the polygon in the browser, then in the Properties frame appears
>> Name Value
>> 1. Population 454.000000 (with 6 additional zeros),
>> Actually the value for population is 454. How to fix and remove this
>> additional 6 zeros?
>> thank for help.
>> staniz
> http://n2.nabble.com/Properties-Value-tp2341900p2351399.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/Properties-Value-tp2341900p2352387.html
