[mapguide-users] Properties Value
Jackie Ng
jumpinjackie at gmail.com
Thu Feb 19 23:13:46 EST 2009
I don't think FDO will actually allow you to change a property's data type if
there is pre-existing data in it.
- Jackie
staniz wrote:
> Ivan, thank for your time and effort trying to solve my problem.
> So far I couldn't change the property type. I follow your instructions and
> also give full access to the sdf file, and copy the internal Sdf file to
> another folder, but still I couldn't change from decimal to Int32.
> The following error come when I apply change to the schema.
> The screennshot error :
> http://n2.nabble.com/file/n2352387/error1.jpg
> Ivan Milicevic wrote:
>> Staniz,
>> Here is instructions:
>> 1. Go to http://code.google.com/p/fdotoolbox/downloads/list and download
>> last version of thisexcellent piece of software made by Jackie.
>> 2. run it and in project explorer: new->connect to sdf
>> 3. Pick your file
>> 4. The connectionshould be added in object explorer
>> 5. Right clockon it and chose "edit schema"
>> 6. Pick your population class and on right side of program (schema
>> designer) change datatype of class
>> Here is screenshot.
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of staniz
>> Sent: Thursday, February 19, 2009 6:50 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: Re: [mapguide-users] Properties Value
>> it's ok, I will wait for the solution.
>> staniz wrote:
>>> I am using MGE and MG Studio 2008 and have layer and sdf file as
>> polygon
>>> feature type. In my table there is one field, a Property Name =
>>> "Population" and Property Type = "double", I checked/selected this
>>> property in "Properties displayed in the viewer" check box. when I
>> select
>>> the polygon in the browser, then in the Properties frame appears
>>> Name Value
>>> 1. Population 454.000000 (with 6 additional zeros),
>>> Actually the value for population is 454. How to fix and remove this
>>> additional 6 zeros?
>>> thank for help.
>>> staniz
>> View this message in context:
>> http://n2.nabble.com/Properties-Value-tp2341900p2351399.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Properties-Value-tp2341900p2357080.html
